Handle bar diameter? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 08-23-2013, 12:25 AM Thread Starter
I've heard maybe they were inch in diameter or bigger. I'm trying to find grips for the bike and need to know the correct size of the bars.
post #2 of 17 (permalink) Old 08-23-2013, 12:31 AM
7/8"
Rebel13 is offline
post #3 of 17 (permalink) Old 08-23-2013, 12:37 AM Thread Starter
Ok thanks buddy
post #4 of 17 (permalink) Old 08-23-2013, 12:44 AM Thread Starter
Are they dual throttle?
post #5 of 17 (permalink) Old 08-23-2013, 01:25 AM
Ndr
If by dual throttle you mean Two throttle cables, the yes. (not sure what else it could mean) One to open, One to close the throttle.
Ndr is offline
post #6 of 17 (permalink) Old 08-23-2013, 09:49 AM
2FAS4U
Use the 7/8" Honda Goldwing grips. The are a little longer.
Also, the grips slip onto the throttle tube on the that side, so don't get the dual cable type.
2fas4u is offline
post #7 of 17 (permalink) Old 08-23-2013, 10:21 AM
while this will work, many types of replacement grips include the throttle tube, therefore you need to know which type of cable arrangement it has (single, double or electronic)
post #8 of 17 (permalink) Old 08-23-2013, 11:16 AM
Stock replacement grip comes with the throttle tube. Most sftermarket grips do not. You will need to cut off the old stock grip and grind/file down the "nubs" on the stock tube to slide the new ones on.
post #9 of 17 (permalink) Old 08-23-2013, 12:25 PM
Exactly!!
Also keep in mind the lenght of the new grips....some are a bit short for our throttle tubes.
post #10 of 17 (permalink) Old 08-23-2013, 01:10 PM Thread Starter
This seems complicated lol. I thought this was a pull off the old grips and screw on the new grips type of job. New to working on bikes.
