speedo cable? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-19-2013, 11:38 AM Thread Starter
oriontheblacksmith's Avatar
speedo cable?
hey guys, my speedometer cable is broken and needs to be replaced. any suggestions/advice on what to get? it looks like the male piece that connects to the gears on the wheel has a slot down the middle that i havent seen on replacement cables.
thanks! happy riding
orion
1985 VN700
$450 ex-basket case
shaved and coastered
dimmer switch replaced
headlight rewired
speedo and tach removed (dont work)
turn signals removed (dont work)
side stand switch removed
new spark plugs
oriontheblacksmith is offline
post #2 of 8 (permalink) Old 08-19-2013, 02:10 PM
Go to a Kawasaki dealer and order one for about $20.00, they might even have it in stock so you could fix it right away.
post #3 of 8 (permalink) Old 08-19-2013, 04:37 PM
Is anyone elses speedo like loud whirlin around in there?
post #4 of 8 (permalink) Old 08-20-2013, 01:55 AM
X2^^^^^ I had to replace my speedo cable about 2 months ago. The local Kawi dealer had to order it in from Calgary and I only had to wait a day or two for it. Price was $23 to 25 CAN.
post #5 of 8 (permalink) Old 08-21-2013, 04:56 PM
Dr. Vulcanstein
jadabull's Avatar
Yeah, it shouldn't be "whirlin" around. Take it off and make sure its greased up. I use regular red bearing grease that's layin around the garage in mine.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 8 (permalink) Old 08-21-2013, 07:57 PM
Shove grease up in the housing and on the cable end?
post #7 of 8 (permalink) Old 08-21-2013, 08:06 PM
smear it all over the cable and get it into the sheath as best you can without it oozing all out.
post #8 of 8 (permalink) Old 08-22-2013, 04:24 PM
I just replaced mine..~$25 from dealer who ordered one. I slid the wire out and rubbed grease end to end as I was told the manufacture's grease was no good and not enough is used.
Greenmountain is offline
