Missing door on rear plastic tool box - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-03-2007, 12:20 AM Thread Starter
Unhappy Missing door on rear plastic tool box
After a recent hour ride, I pulled into the garage and noticed the door to the plastic tool box on the rear was missing. I know it was locked before I left and I don't suspect anyone messing with it. I didn't stop anywhere.
I keep registration, insurance, tools, manual etc in there, so I'd like to have it locked.
Anybody replaced this thing? Did you replace the door only or the whole box? Where did you find the replacement?
Can you get the lock re-keyed to the ignition key?
Pain in butt...
Texas Cruiser
Texas Cruiser is offline
post #2 of 9 (permalink) Old 01-03-2007, 12:51 AM
Spriddle's Avatar
Yep,that happened to me to last year.I was riding it home after buying it (100 mile ride).On a stop I found the doors lock was missing and the door was hanging open.By the time I got home the plasic hinge gave out and the door was gone also.Called the dealer I bought it from and They got a new door and lock to me in a week, (I assume from kawasaki). Good news is you should still be able to buy one, Bad news ,you have 2 keys now. When you get your new door, put a bead of silicone around the nut that holds the lock on,it can easily vibrate loose causing the lock to fall out.good luck
Spriddle is offline
post #3 of 9 (permalink) Old 01-03-2007, 06:32 AM
With the very minimal security the toolbox offers, I just ended up replacing mine with a very small backpack.
You can kinda see it in THIS pic, or THIS one.
And, a locksmith should be able to do some of his magic to get the original key to work on a new lock.
post #4 of 9 (permalink) Old 01-03-2007, 08:25 AM
Crobins365's Avatar
In addition to the silicone on the lock, put a good piece of duct tape on the inside hinge of the door. That way if the lock goes, you'll still have a chance of keeping the door.
C
Crobins365 is offline
post #5 of 9 (permalink) Old 01-03-2007, 06:16 PM
Depending on how close the keys are you can probably rekey it yourself. The lock cylinder is held together by a snap ring. If you take it apart you should be able to rearange the tumblers in it until it works with your old key. The trick is find the combination that make the tumblers flush when the key is inserted.
JamieB is offline
post #6 of 9 (permalink) Old 01-03-2007, 06:36 PM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
Somebody keep an eye on this guy, he sounds good....LOL.
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #7 of 9 (permalink) Old 01-04-2007, 12:46 AM
HAWK
Ccspinner's Avatar
I rekeyed my back door lock, The lock fell out and the one I got came with 2 keys. I was lucky they were only 1 tumbler away so I cut the key to work with my ignition and removed the one tumbler from the rear door. Now I have 4 keys for the bike.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 9 (permalink) Old 01-04-2007, 01:01 PM
Uber Member
you could also use a piano hinge and rivet (use some blind rivets, easy to use and cheap) it in place of the plastic thing, that would add to the security of the box, and with the loctite on the nut on the lock, it shouldnt go anywhere. i would do it to mine, since it just broke, but i am pulling all of that off anyway.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 9 (permalink) Old 07-18-2008, 04:20 PM
When I saw that little lock assembly was almost $50 from Kaw, I knew there was no way. (You can't say Kawasaki nickel and dimes you on parts; they just mug you and take your whole wallet.) Took the case up to my local locksmith shop and they had me one for $7-8. They had to bend the lock tab to make it fit tight, but it works good.
And the silicone is good advice. Two weeks later mine came off, but luckily I was able to find it on the road. A wide metal washer to go on the back is a good idea too, so you can tighten it down real good.
2001 VN750
16k miles
Ear Shave & Coastered
EMGO & UNI Filters
Kuryakn ISO Grips
Stebel Nautilus Air Horn
Clear Alternatives LED Tail Light
TOC MCCT
AGM Battery
Custom Footpegs
LED Voltmeter
tilak is offline
