Highway Pegs for Kaw Engine Guard ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 11-13-2006, 06:27 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Location: Southwest of Ruby Ridge, Geiger Heights, Washington, USA.
Question Highway Pegs for Kaw Engine Guard ?
Are there any Highway Pegs that fit on the Kawasaki Engine Guard?
The right side looks like it would be a tight fit if possible at all?
If there are any good fits where can they be purchased?
"When the sun's comin' up,
I got cakes on the griddle.
Life ain't nothin' but a funny funny riddle,
Thank God I'm a Country Boy!"
norsseman is offline
post #2 of 8 (permalink) Old 11-13-2006, 06:37 PM
Search Goddess
Dianna's Avatar
Several have used the Kury right angle pegs #4059 mounted on the outer upper edge.
http://www.kuryakyn.com/products.asp?bn=Metric&ci=3258
4509 // $149.99 _ORDER NOW
Long Right Angle Mount with Dually ISO-Pegs and 1" Clamps (pr)
U.S. Patent # Des. 405,393 and 411,440
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 8 (permalink) Old 11-13-2006, 07:10 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Thanks Dianna. Those Kury Peg's look sharp and should be a good fit.
Found Kury #4509 at MC Assessories, Miami, FL for 126.73 + 15.
post #4 of 8 (permalink) Old 11-13-2006, 08:29 PM
Search Goddess
Dianna's Avatar
The Kawasaki crash bar is not symetrical left to right because it goes farther out around the the right side exhaust pipe. The pegs will end up with one closer in than the other. Not too noticeable but it's there.
You can also adjust one in and one out to even it up some. the Kury's snug up pretty good but if you have a problem a thin piece of rubber tubing or mat (like those used to open jar lids) should keep them in place.
Like I said though, the Kury's go on easy and stay put.
They are usually mounted on the top tube so it is an easy drop down and swing in to the shifter or brake pedal
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 8 (permalink) Old 11-14-2006, 10:52 AM
"ya can't live forever"
artman's Avatar
I bought some MC pegs and they fit OK. They do however have to be mounted a little far forward very close to the bend on each side. Also I have them angled upward around 20 degrees to give me more clearance for the brake and shift levers. Cost was about $ 56.00. I'll see if I can find the part number.
Part # is 209 www.mcenterprisesusa.com
artman is offline
post #6 of 8 (permalink) Old 11-15-2006, 08:13 PM
Wall's Avatar
Take a look at these photos of my bike (excuse the dust, from tile installation work ongoing in my house). The pegs are Kuryakin Pilot pegs mounted with 4503 right angle mounts. I got them from Cruisercustomizing.com.
ID:	170   Click image for larger version
ID:	171   Click image for larger version
ID:	172   Click image for larger version
Wally Colly
2004 VN750 "Freedom"
Wall is offline
post #7 of 8 (permalink) Old 11-16-2006, 12:14 AM
I used Kuryakin on mine and still didn't care for the position. I built extenders for the pegs out of al. channel. The extension of 1/2" and 1" worked well for me.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #8 of 8 (permalink) Old 11-16-2006, 05:21 PM Thread Starter
Gnarly Jokester
norsseman's Avatar
Just in case I have to use some Aluminum channel, what thickness did you use?
