Installing Heated Grips Switch - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-29-2013, 04:54 PM Thread Starter
Roach's Avatar
I decided I wanted to install my new heated grips switch in the instrument cluster to give it a "stock" look.
It was a tight fit, but I got it in there.
The trick was to use the 3/4" hole saw from the back, to get the hole centered.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #2 of 8 (permalink) Old 04-29-2013, 04:58 PM
Looks great....good job !
WilliamTech
post #3 of 8 (permalink) Old 04-29-2013, 05:38 PM
Mike DeAngelo's Avatar
Wow! Looks really good.
Mike DeAngelo is offline
post #4 of 8 (permalink) Old 04-29-2013, 06:11 PM
JM2001's Avatar
Nice clean looking job.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 8 (permalink) Old 04-29-2013, 07:36 PM
soltz's Avatar
Cool Burrrrr
Looks super, good idea doing it from the back. Have you considered moving to a warmer climate
Many many mod's
soltz is offline
post #6 of 8 (permalink) Old 04-30-2013, 12:33 PM Thread Starter
Roach's Avatar
Hahaha. Yeah, all the time.
Street
Dirt
Roach is offline
post #7 of 8 (permalink) Old 04-30-2013, 12:34 PM
looks good!
I am surprised it fit...lol
I used the same location to mount my Battery monitor LED....but that was MUCH smaller diameter.
nice job!
post #8 of 8 (permalink) Old 04-30-2013, 12:35 PM Thread Starter
Roach's Avatar
Turns out I overlooked one detail. The bracket on the back makes for a tight fit for the wires. I ended up having to bend the tabs on the back of the switch to make it work.
Street
Dirt
Roach is offline
