Highway Pegs? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-09-2013, 01:07 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
Highway Pegs?
I have the engine guard, but I don't have highway pegs. I'm 6'2", and I'm thinking it would be nice to be able to stretch out on long rides.
To all the tall riders out there, are hi-way pegs worth getting? If so, can anyone recommend any that aren't too expensive.......
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 12 (permalink) Old 04-09-2013, 01:54 PM
sparkingdogg's Avatar
well worth the money for tall or short riders, you need offsets to be able to dial in the perfect spot, make sure you check the od of your mounting point... here are some kury's but you can find chinese knock-offs for a lot less
http://www.ebay.com/itm/KURYAKYN-799...ht_1910wt_1161
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
sparkingdogg is offline
post #3 of 12 (permalink) Old 04-09-2013, 02:30 PM
SlowBox's Avatar
Short answer is YES. I was looking at some highway peg mounts that go on the empty bolts above the controls that a member here makes, but them plus the pegs were almost $300 and out of my price range. My solution was to get another stock seat and cut a lot of foam out of the bottom and back of where I sit so I could be further back. I also found a stellar deal on some forward controls so I doubt I'll ever get any actual highway pegs for this bike.
SlowBox is offline
post #4 of 12 (permalink) Old 04-09-2013, 03:47 PM
Stones750's Avatar
Yes they are worth it, I am the same height and bought some bike master clamp on o-ring pegs. I also had to get some foot peg mount extensions to get them where I wanted but i can't seem to locate the part number now. You could probably fab the extensions from some square steel, basically the bolt brom the clamp would go into one end wit a nut welded in then drill the hole to mount the folding peg to the outside.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #5 of 12 (permalink) Old 04-09-2013, 04:24 PM
Eli
Eli's Avatar
peterherrm,
Where did you get your engine guard? I a really want to buy one? How is it?
Eli is offline
post #6 of 12 (permalink) Old 04-09-2013, 05:57 PM
I'm not as tall as you and I definitely wanted some highway pegs after my first couple long rides (which weren't that long).
Initially I got some 30 dollar pegs that mounted on the side of the crash guard (horizontal part - kawasaki engine gaurd). They worked but were still to close to me to where I couldn't really stretch my legs forward. I could basically only change positions to where my feet were higher but knees still bent in basically same position as when using the normal pegs.
I found a set of used Kuryakyn offset pegs. I mounted these on the vertical bars of the engine guard. I also got the 2.xx" extensions to make them a little wider. I'm still figuring out the exact position I want them in but had a chance to use them last weekend and it made a big difference. I will get some pics on here when I can.
Good luck
(I probably wouldn't have gone with the Kury's if I hadn't found the good deal - would have had to go with some knockoff)
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #7 of 12 (permalink) Old 04-09-2013, 08:08 PM
I got rid of the floorboards, but here is a cheap set hung on the Fire and Steel engine guard.
https://www.vn750.com/forum/picture.p...pictureid=2397
https://www.vn750.com/forum/picture.p...pictureid=2398
post #8 of 12 (permalink) Old 04-09-2013, 08:57 PM Thread Starter
peterherrm's Avatar
Originally Posted by Eli View Post
peterherrm,
The engine guard came with my bike.... If you ever take it off, it's a real pain in the ass to get back on......
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #9 of 12 (permalink) Old 04-09-2013, 08:59 PM Thread Starter
peterherrm's Avatar
Thanks everyone for the suggestions. I had figured that just getting pegs that go out to the sides would only just raise the area I put my feet, not stretch my legs out at all, so I guess I need to look for some sort of offset.
As soon as I put my new MCCT's in, this will be my next project......
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #10 of 12 (permalink) Old 04-09-2013, 10:32 PM
Chuck A.'s Avatar
Pricey, Kurys, 3 different part numbers, can ride several hours and the legs are happy.
Chuck A. is offline
Tags
hi-way pegs , highway pegs , pegs
