New way to glue grips - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #11 of 17 (permalink) Old 10-16-2012, 11:58 AM
Originally Posted by M_Angell View Post
But what if i dont want to cut up my expensive kury grips?
Maybe that's the lesson here... I've actually never had a grip slip on me. I just replace then every 3-4 years because they wear. Cheap grips it seems don't slip. I use clear spray lacquer (kinda like hairspray eh?) and when the grip gets worn I cut it off with a razor blade and put on a new one.
Likely helps to get the right size too. If your grips are really slipping that much you might be holding them too tight.........
post #12 of 17 (permalink) Old 10-16-2012, 12:21 PM
Guess it depends on the style of grip too. Moulded rubber grips have a harder time slipping it seems. Metal grips with rubber inserts inherently have more movement because they have more parts. Micro movements caused by vibration will break the adhesive free.
After i got my kury grips i havent had them slip on me once.
post #13 of 17 (permalink) Old 10-17-2012, 01:59 AM
Let's Ride!!
DaveT319's Avatar
Thanks, tried this today, worked great.
DaveT319 is offline
post #14 of 17 (permalink) Old 10-17-2012, 05:07 AM
I bought a set of grips when I bought the bike and used the grip glue that came with them on the left side, and so far it hasn't moved. I know it's going to be major surgery to get it off when I need to replace them. The right side I had to buy another barrel because when I tried to get the grip on it busted the plastic all to pieces.
I'm going to hunt around and find a metal barrel to replace it when I do replace the grips.
TSmith68 is offline
post #15 of 17 (permalink) Old 10-17-2012, 01:14 PM
what worked?? cutting them off or WD-40??
post #16 of 17 (permalink) Old 10-17-2012, 02:00 PM
Let's Ride!!
DaveT319's Avatar
The rubber cement.
DaveT319 is offline
post #17 of 17 (permalink) Old 10-17-2012, 02:35 PM Thread Starter
JCee's Avatar
The rubber cement.
I was surprised how well it worked myself. Time will tell how well it holds up but they seem pretty snug.
JC
VROC #35307
2013 HD Iron 883
2002 VN 750
JCee is offline
