Kuryakyn Shift Peg - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 10-04-2012, 08:35 PM Thread Starter
Exclamation Kuryakyn Shift Peg
Does anyone one know the correct part number for the Kuryakyn Shift Peg for a '97?
On Kuryakyn website it show two that I believe would fit but not certain. Part number KY-4034 or KY-4036.
Please help..
Thanks...
hacez529 is offline
post #2 of 13 (permalink) Old 10-04-2012, 09:02 PM
Originally Posted by pittdave View Post
Kuryakyn 4036 shifter cover fits just fine. So to recap, if you want to get a set of pedal covers...4029 is the brake cover, 4036 is the shifter cover.
ride on!
Read post 10 in this thread
post #3 of 13 (permalink) Old 10-04-2012, 09:51 PM Thread Starter
THANK YOU Slim!!!
Perfect. That's what I thought but I needed to be certain.
Thanks
hacez529 is offline
post #4 of 13 (permalink) Old 10-05-2012, 08:54 AM
JM2001's Avatar
I like Kuryakyn 8851 better. It matches the 4029 brake cover but looks more like a shift peg. Fits fine. jmo
http://www.powersportsuperstore.com/...ctCode=4096299
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 13 (permalink) Old 10-15-2012, 12:25 AM Thread Starter
Red face How about for the front and passenger pegs
Now that I have done the brake cover and shift peg, I want to do the front and rear pegs. Does anyone know the Kuryakyn model number that fits the '97 750?
Thank you advance for your help..
hacez529 is offline
post #6 of 13 (permalink) Old 10-15-2012, 12:40 AM
Arrow
Have you considered Floorboards ?
WilliamTech
post #7 of 13 (permalink) Old 10-15-2012, 02:26 PM Thread Starter
Floorboards
WilliamTech
Actually I haven't. Is that an easy conversion or do I have to do modification? I prefer to just remove a bolt, replace and the put bolt back on. LOL
What floor boards would you recommend?
Thanks
hacez529 is offline
post #8 of 13 (permalink) Old 10-15-2012, 02:41 PM
Arrow
Thanks
Floorboards bolt on just that easy. No modification required.
I have read one member actually preferred KM's Floorboards
(actually switched ), over another aftermarket brand Floorboards.
WilliamTech
post #9 of 13 (permalink) Old 10-15-2012, 03:11 PM
Thanks
http://www.chadsbike.com/floorboards.htm
post #10 of 13 (permalink) Old 10-21-2012, 10:06 PM Thread Starter
Does anyone have an idea or quick fix for the kuryakyn 4036 pads? I installed it removing the rubber piece that was originally on the shifter peg, then after a ride for the day, when I got home I noticed the the rubber pads were protruding from the cover. I then pushed them back in and then again after again the same situation. What am I doing wrong?? Help PLEASE...
Thank you
hacez529 is offline
