Quick Disconnect Windshield - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-08-2012, 01:41 AM Thread Starter
Has anyone ever found or used a quick-disconnect windshield for the VN750? Is it even possible?
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #2 of 13 (permalink) Old 05-08-2012, 05:29 AM
2FAS4U
2fas4u is offline
post #3 of 13 (permalink) Old 05-08-2012, 08:15 AM
Both the PF3 and the PS2 can be taken off/on quickly..
Most good screens use ball joint connectors ... So they pop off if you hit them in an accident. Some can be "popped" off by hand and popped back on too.
Short screen usually have only two mounting points. 20 seconds with a socket wrench gets them off quickly too.
Guess it matters what you call "quick"....
post #4 of 13 (permalink) Old 05-08-2012, 08:15 AM
JM2001's Avatar
Mine is not quick release but goes on and off in about 5 minutes.
http://www.cruisercustomizing.com/ti...KAK-46001-010A
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 13 (permalink) Old 05-08-2012, 10:13 AM
I've got a Memphis Shades "Memphis Fats" windshield. After initial install, which involves relocating turn signals (they make a kit for that), it's pretty quick. Quick turn of 4 hex bolts (I've always got the wrench in the bike) and it slides right off. Tighten them a bit to make sure the don't vibrate out while riding and you're set. Putting it on or taking it off is less than a 5 minute process, and I'm confident that it'll stay put.
Again, how quick is 'quick?' For me, this is quick.
Hippie
2005 VN750 upwards of 14K (haven't looked lately)
Mods:
AGM Battery
Degoated
Headers wrapped
Custom paint
hot_rod_hippie is offline
post #6 of 13 (permalink) Old 05-08-2012, 11:23 AM
I have the Plexistar II installed. The PS2 and PS3 both mount the same way. They can easily be removed in a few minutes if needed. Re-install is just as easy.
post #7 of 13 (permalink) Old 05-08-2012, 11:49 AM
Thought that was the first thing I wrote........lol.
post #8 of 13 (permalink) Old 05-08-2012, 06:52 PM Thread Starter
I saw one on a Harley that had two spring clips to release it. I gues that's what I thought was "quick".
But 5 minutes is pretty fast too. When off - does mounting hardware stick out all over?
eusjma is offline
post #9 of 13 (permalink) Old 05-08-2012, 07:15 PM
JM2001's Avatar
No, just 2 chrome brackets on the handlebars. Don't even notice them.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 13 (permalink) Old 05-08-2012, 07:37 PM
just validating it for ya!
When you remove the PS...the only things left on the bike are 2 clamps that remain on the handlebars, and 2 clamps on the forks. You remove the windshield by unscrewing a knob (for lack of a better description) and the brackets come off with the windshield.
in the photo the clamps are mounted just above the horns on the forks....and you can see the one on the handlebar(in left side of this photo)
