saddlebag support bolts??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-07-2012, 11:30 PM Thread Starter
pittdave's Avatar
I hope someone can tell me what size i need for the F/S saddlebag supports. The bolts that come out of the grab rail are M8-1.25 50mm. I went everywhere and after adding the bags 60mm or 70mm would not work on the rail. 60mm were fine in the back through the bracket and i added the nut. The front ones are the issue. After totally tightening the back on the right side, i was able to get the 70mm to work on the front, but it was a MAJOR hassle. And after many loud expletives that i'm sure most of the neighborhood did not approve of, i could not get the left front to thread. I would assume 75mm or 80 would work, but no one any that long in stock
What to do.. What to do
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 3 (permalink) Old 05-08-2012, 08:53 AM
JM2001's Avatar
You should be able to get M8s locally. If you have to order them, I would go to Home Depot and get 5/16 x 3" bolts ( and nuts ) and use them until I got the M8s. The 5/16 should thru bolt fine. A little advice- If you're attaching a bracket with 2 or more bolts, DO NOT tighten one side down first. Get both bolts threaded in then tighten both of them equally side to side.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 3 (permalink) Old 05-08-2012, 11:00 AM Thread Starter
pittdave's Avatar
WHAT an adventure.. Finally found a place that had 80mm in stock. What can't things be as easy as they are supposed to be???
Pittsburgh Dave
pittdave is offline
