reclaiming your black plastic parts from sun fade - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-28-2012, 08:05 PM Thread Starter
I just used this trick i found from you tube on removing the whiting from plastic. my rad cover was very sun bleach so i took my heat gun and with cover remover from bike i used the heat gun to make the plastic shine again. don't stay in one spot at all or you'll melt the plastic fast but sweep back and forth. i kept the gun about 1 inch from the plastic. looks a hundred times better now.
1991 VN 750
Mortagleus is offline
post #2 of 4 (permalink) Old 04-28-2012, 10:18 PM
Patriot Guard Rider
The DEUCE's Avatar
I normally apply WD-40 every once in awhile. Someone on here soaked their plastic in used motor oil with the same results.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 4 (permalink) Old 04-28-2012, 11:26 PM Thread Starter
The heat gun will also remove the whitening from plastic that has been bent. thia works for any color plastic that i know of
1991 VN 750
post #4 of 4 (permalink) Old 04-28-2012, 11:54 PM
Even though a heat gun may work, your actually drying out the plastic even more! Plastic is made from oil and a heat gun loosens up the mixture and brings some oil back to the surface. Applying actual oil is best.
Rebel13 is offline
