turn signal relocation bracket install problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-27-2012, 10:55 PM Thread Starter
pittdave's Avatar
I picked up the Kaw luggage rack and T/S brackets off Ebay and on the install today I am running into 2 problems and I wnat to make sure of this before I do anything else...
1. With the brackets installed, the T/S elec leads are now too short and cannot reach the connectors. Am i right on this or is there some slack I am missing.. if no slack, i guess i have to splice in some longer wire??
2. The screw that holds on the T/S.. the hole in the bracket is not threaded as the grab rail is.. so I guess i need to get some nut/bolt combo to hold those on??
Also.. what is the tongue on the bracket that points down for???
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 10 (permalink) Old 04-27-2012, 11:10 PM
The Tongue is for the helmet locks, as for the screws.. yes you are going to need to find nuts for them. The original turn signal relocate brackets came with extensions. so yes you are going to need to splice in longer wires.
post #3 of 10 (permalink) Old 04-27-2012, 11:18 PM Thread Starter
pittdave's Avatar
youre full of all sorts of good news
Pittsburgh Dave
pittdave is offline
post #4 of 10 (permalink) Old 04-27-2012, 11:40 PM Thread Starter
pittdave's Avatar
at least with getting new screws and bolts, it makes it OK that I had to drill out one of the original mount screws
Pittsburgh Dave
pittdave is offline
post #5 of 10 (permalink) Old 04-28-2012, 12:53 AM
I think you are talking about the tongue that hangs down with 1 hole in it. That would be to mount saddle bag brackets if you have them. The helmet locks get relocated at the back.
post #6 of 10 (permalink) Old 04-28-2012, 03:50 AM Thread Starter
pittdave's Avatar
thats it.. i will looking for those as well
Pittsburgh Dave
pittdave is offline
post #7 of 10 (permalink) Old 04-28-2012, 08:20 AM Thread Starter
pittdave's Avatar
just to clarify.. i've seen many of those saddlebag supports and if one end goes on that tongue, then where does the other end go.. It looks like both ends would connect at the grab rails??
Pittsburgh Dave
pittdave is offline
post #8 of 10 (permalink) Old 04-28-2012, 08:58 AM
The way the fender rails are curved one end goes in the rail and the other goes in the tab as mentioned before.It mounts that way to make the bottom of the support level and therefore supporting your bag even from front to back.
post #9 of 10 (permalink) Old 04-28-2012, 11:47 AM
Does the second picture on this thread help you visualize it?
https://www.vn750.com/forum/showthread.php?t=9851
Also shows the signals and helmet locks mounted.
post #10 of 10 (permalink) Old 04-28-2012, 12:14 PM
Member? ... check.
ZCraggRatt's Avatar
Good Post OH.
hope this helps.
ID:	4478   Click image for larger version
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
