DIY Luggage Rack - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-18-2012, 05:28 PM Thread Starter
Ndr
DIY Luggage Rack
So, since finding a luggage rack brand new for our bikes seems to be all but impossible (excluding of course the over priced ones on eBay) I decided to start building one for myself.
Unfortunately, I do not weld. So to make something that works, I went with a piece of flat steel bar 1" wide and 1/8" thick. I'm using the bolts that attache the sissy bar to the grab bar as mounting points and bending the bar around the toolbox.
At the moment, I am missing the back half of the toolbox and have one on order soon to be delivered, so I am waiting on this to come in to proceed to the next steps. Once I have the toolbox in place, I will be able to measure for placement of the crossbars as well as figure out how much of the back lip of the tool box I will need to shave out to accommodate the steel bar.
he crossbars will be the same 1/8" steel bar with tabs bent down and holes drilled and taped to be able to thread in a 6mm bolt to hold wither end in place.
then of course once assembled, primed and painted. I may or may not bondo over all of the dents and dings from the hammer blows.
Ndr is offline
post #2 of 13 (permalink) Old 04-18-2012, 06:21 PM
pretty good smithing skills even if you don't weld,dress the hammer marks with a flat file and spray it with a primer/filler and then wet sand it and then paint.
post #3 of 13 (permalink) Old 04-19-2012, 03:11 AM Thread Starter
Ndr
Cool, thanks for the tip.
Ndr is offline
post #4 of 13 (permalink) Old 04-19-2012, 07:26 AM
here is my solution... 197? GL luggage rack
still working on the final mounting brackets so i can loose the stock fender struts and back rest.
post #5 of 13 (permalink) Old 04-19-2012, 07:40 AM Thread Starter
Ndr
Looks pretty cool. I opted to keep the stock seat and extended sissy bar that came with the bike in part because its part of the look I like about the bike, and also less money that I have to spend on stuff...
Unfortunately though, I may have to wait to finish my rack. I pretty much shattered the base of my bench vice from all the hammering. But then, I guess that's what I get for using a $20 vice as an anvil...
Ndr is offline
post #6 of 13 (permalink) Old 04-19-2012, 07:54 AM
stock seat will still be able to go on.. that is why the stock extended back rest is there.. Personally don't like the stock seat. but I wanted to make this mod easy enough that a guy with out any skills could bolt it up.. so far I think I have accomplished that. btw... I have 50 bucks invested in my seat, luggage rack, and my KF&S extended backrest. so al lin all its a very cheap mod.
post #7 of 13 (permalink) Old 04-19-2012, 12:07 PM Thread Starter
Ndr
That's not bad at all. I spent almost that much buying a new piece of vinyl to recover the seat. I figure the luggage rack to cost me about $20 in materials, and I'm also looking at putting together a pair of lower deflectors to mount on the forks. That should be around another $15-20.
So far I like the stock seat, seems fairly comfortable, but I haven't had a chance for a long ride yet. The most I've put in in one go is 60 miles.
Ndr is offline
post #8 of 13 (permalink) Old 04-19-2012, 01:50 PM
the stock seat was fine for me... I could have left it... but i couldn't stretch out far enough... the seat i made dropped me down about 1 1/2" and backwards about 6-8". now i feel like I have forward controls even though they are standard mids.
post #9 of 13 (permalink) Old 05-02-2012, 02:09 PM Thread Starter
Ndr
Finally Finished...
I still need to retouch the paint after drilling the two holes in the center cross bar last minute. Will use the holes to mount a sissy bar bacg to the rack, and perhaps in the future a trunk.
Not happy with the gloss black. will likely redo it in flat black, if I can get over being too lazy to pull it back off the bike.
Also, I'm thinking that I may relocate the helmet locks to the sides of the rack.
Ndr is offline
post #10 of 13 (permalink) Old 05-02-2012, 02:52 PM
looks good....nice idea.
Just curious about your red lenses on the rear blinkers.....did you convert to running lights? if so, what type did you install.
