My Seat Mod Writeup (Backrest Delete) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-24-2012, 06:19 PM Thread Starter
PaleRider's Avatar
Hey there all, Just wanted to share how i went about altering my seat to fit my needs and style.
Materials/Tools Used:
*Hacksaw
*Needle-nosed Pliers
*10mm (should be a given)
*Staple gun
*Scissors
*Silver Sharpie
*Beer
*2 "L" Brackets I had lying around
*2 Screws I had lying around
1. I first removed the plastic storage compartment and the seatback frame.
2. Then I put my brackets into the holes left from where the seatback frame attached using the original bolts. (See pics below).
3. Next marked the holes where i was going to attatch the brackets to the seat with screws.
4. Use your needlenose to pull out the staples under the seat, peel back foam and cut (hacksaw) so the seat pan is flush with the metal bracket that holds the turn signals (i marked it off with a silver sharpie).
5. Use scissors to cut the foam to match the seatpan.
6. Trim excess leather but leave enough to tuck under and re-staple (make sure to pull tight. a second set of hands would help.
7. I then cut the plastic piece out of the former rear end and slotted it between the small grooves in the metal (see messed up pic below) to give it a finished look.
8. Then to hide the fact that I'm not an expert in upholstery I strapped on a rollbag that i originally had on the front to cover that and serve as my new place to store my documents.
Final shot (before moving the rollbag).
Hope this is helpful to at least someone. and please spare me, its my first writeup.
Cheers,
PaleRider
2004 VN750: Custom Seat, NGK Plugs/Wires, Drilled Baffles, 12 inch apes
2006 VW GTI 6MT: 3" TBE, CAI
2006 Malibu Maxx SS (Wifes ride): Straight Pipes
PaleRider is offline
post #2 of 16 (permalink) Old 03-24-2012, 08:44 PM
i like the look with out the roll bag better.. but all together love the look.
post #3 of 16 (permalink) Old 03-24-2012, 09:24 PM
MaDeInSin's Avatar
Nice Job.. Very Creative.. Sharp.
It's always nice to see people thinking outside the box.
Ride Safe.
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #4 of 16 (permalink) Old 03-24-2012, 10:04 PM Thread Starter
PaleRider's Avatar
I agree SVR. I will relocate it to the front once i get a chance to re vamp the back of the seat rid it of the wrinkles.
post #5 of 16 (permalink) Old 03-25-2012, 08:26 AM
to get rid of the wrinkles:
trim the vinyl about 1" from the edge of the seat pan. then cut some relief notches around the curved edges. stretch the vinyl tight tight and restaple. Take some pictures of the back of the seat and the underneath of the seat and I can photo-shop what I am talking about.
post #6 of 16 (permalink) Old 03-26-2012, 08:52 AM
Good job there. Now you don't have to lift your leg so high! lol
post #7 of 16 (permalink) Old 03-26-2012, 09:21 AM
MaDeInSin's Avatar
Very Nice Mod and an overall sharp looking ride.
Accomplishments;
Iridium Plugs
Lubed the Spline
Re-Jetted
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
post #8 of 16 (permalink) Old 03-26-2012, 10:15 AM
I was looking at your pics again. You might want to tighten up that front bag. It looks close enought to your front fender to hit when you run over a bump or hard stop. This will eventually start to mark your paint.
post #9 of 16 (permalink) Old 03-26-2012, 10:18 PM Thread Starter
PaleRider's Avatar
It was on there like that when i purchased it. It has since been corrected, but thanks for the heads up.
post #10 of 16 (permalink) Old 08-29-2015, 09:11 PM
*Hacksaw
*Staple gun
*Scissors
*Silver Sharpie
*Beer
Cheers,
PaleRider
I did something similar to mine today. I really like the way it turned out. Instead of working with the old document compartment, I decided to put my eye protection case in between the grab rails. It fit perfectly and was exactly what I needed to hide the bolts holding the seat on. I used the bottom holes in the grab rails to bolt the seat on, instead of the top so that I could still use the sissy bar that came with my bike (with slight modification) so that I can continue to use it if I need to carry anything extra that I need to strap to it. See the pictures attached:
ID:	25618   Click image for larger version
ID:	25626   Click image for larger version
ID:	25634   Click image for larger version
ID:	25642   Click image for larger version
dseidler is offline
