Helmet lift off in 3...2...1... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 03-24-2012, 05:04 AM Thread Starter
Xerik
LOL, sorry title was spur of the moment.
Any one else have this problem with full face helmets? Where at higher speeds say 70+ the helmet feels as if its trying to lift your head off the body?
Is there anyway to help stop it?
Maybe a chin wind gaurd at the bottom?
Also bought me a new helmet!!!
A Bell Arrow Strafer helmet... Might need to get bike repainted to match helmet :P
Engelsseele is offline
post #2 of 25 (permalink) Old 03-24-2012, 07:44 AM
If you experience helmet lift at speeds that low you need a different helmet.I have Vega Altura which I really don't like that well but it doesn't act squirrelly untill around 125 to 130 MPH ,Yours is doing it at normal highway speeds ,thats a distraction you don't need and is actually dangerous.
Is it the Bell that's doing this? Does it fit you well?y It is very important that it does,Try an Icon ,or one of the better brand Helmets out there ,if money is an issue buy the best you can afford.ZR1 makes some very affordable helmets that I have heard good things about.
post #3 of 25 (permalink) Old 03-24-2012, 08:21 AM
JM2001's Avatar
I think you need a properly sized helmet. Yours must be too big.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 25 (permalink) Old 03-24-2012, 08:55 AM
X2^ and I have found some are just poorly designed ,also any different windscreens affect helmet performance differently.If you have no windscreen ,it is definitely a helmet issue.
post #5 of 25 (permalink) Old 03-24-2012, 09:59 AM
MaDeInSin's Avatar
http://video.about.com/motorcycles/H...cle-Helmet.htm
Check this out.. Sounds like your helmet is too big for you.. When you first get your helmet it should almost be "to tight" and it will break in...
Hope you get things straight.
Good Luck!
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #6 of 25 (permalink) Old 03-24-2012, 10:22 AM
your helmet is the right size.. but you might want to look for a larger head...
post #7 of 25 (permalink) Old 03-24-2012, 10:47 AM
Patriot Guard Rider
The DEUCE's Avatar
X2
VN750 #9300 & VROC #33453
The DEUCE is offline
post #8 of 25 (permalink) Old 03-24-2012, 02:17 PM
I take helmets seriously. Either your helmet is too big or not fastened properly, or, like I once did, you have a windshield from hell. My helmet fit perfectly, but above 70 mph the wind would cause it to lift up and choke me. Finally it open the shield, and blew it right off. Near new $40 shield. Went straight home, ripped that windshield off, put on my other FF helmet, and went back to riding. What a difference. And what a shame. $300+ windshield, and it looked great. But I take exception to motorcycle accessories trying to kill me. Sold the shield for $50. Still have the bike specific mounting hardware, maybe I'll make some highway pegs or something out of it some day.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 25 (permalink) Old 03-24-2012, 10:32 PM Thread Starter
Xerik
Actually it's the right size as far as fitting goes I can shake my head and the helmet moves with my head and when I stop the helmet stops. There is no slipping slopping or slapping on my head on any part. I've done the front roll test and the helmet stays on my head.
*Grab back of helmet with strap on securely and roll it forward.*
Actually this is a Icon helmet a Alliance SS type 1. I have had the helmet for 4 years now. I had a ninja 250 before this bike and it was fine then. Even when I ride my fathers KLR 650 i don't have the problem with the helmet just on my Vulcan 750.
post #10 of 25 (permalink) Old 03-24-2012, 11:27 PM
You have a good helmet and sounds like it fits you ,do you have a windscreen on your bike?If so then it needs some adjusting,if not you may need one.
I actually had to cut about 2' off my windshield on my 1500,it was terrible when it was taller also,you are also riding in a completely different posture than you were on the Ninja and that may affect the way it feels too.
