GPS mount - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-09-2012, 01:02 PM Thread Starter
JM2001's Avatar
GPS mount
Has anyone tried this mount? Price seems pretty good.
http://www.jpcycles.com/product/445-221
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 15 (permalink) Old 03-09-2012, 01:14 PM
I haven't used one but it looks like a pretty good product ,I went on a little further and found one for smartphones too,My android has a gps with turn by turn on it and I would like to use it and a water resistant case like that one seems to be the ticket,Thanks for sharing,and the price is decent as well.
post #3 of 15 (permalink) Old 03-09-2012, 01:27 PM
I know the RAM Aquabox is sold as "water proof" not "water resistant" :
http://www.ram-mount.com/aqua_box_mo..._box_mount.htm
That be my choice , especially if the GPS you have is not water proof itself.
post #4 of 15 (permalink) Old 03-09-2012, 01:57 PM Thread Starter
JM2001's Avatar
The RAM Aquabox looks good. Seeing as I need to buy another GPS I guess I'll go the cheaper route and get the Arkon mount.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 15 (permalink) Old 03-09-2012, 02:00 PM Thread Starter
JM2001's Avatar
I didn't see the Smartphone mount. Hope it can work for you.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 15 (permalink) Old 03-09-2012, 02:11 PM
My only comment on this is look at how it mounts & look at your handlebars. Is it positionable for proper veiwing?
post #7 of 15 (permalink) Old 03-09-2012, 02:35 PM Thread Starter
JM2001's Avatar
Originally Posted by kanuck69 View Post
My only comment on this is look at hot it mounts & look at your handlebars. Is it positionable for proper veiwing?
That's a good point. They say it rotates 360 degrees so I would think it would work ok. In one of the photos it shows the GPS mounted on pull back bars similar to ours and it looks good.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 15 (permalink) Old 03-09-2012, 03:25 PM
I have this one on my bike. It is waterproof and works well. I used it when I drove from NJ to DC for rolling Thunder. My TomTom is small, so I used the foam pads that came with it behind the unit to keep it towards the plastic panel (for touch screen).
I like it because it mounts easily and is removable very easily. It is stable and you can still use the touch screen while it is in the case. There is a pass through grommet on the back that the wire can exit the case. I leave the ball mount clamped to the handle bars and just detach the case. The GPS drops right in the case via a waterproof zipper on the perimeter of the case.
I can still hear the speaker call out directions as I drive with this.
My only complaint is that between direct sunlight, and the plastic front of the case, it does at times make it challenging to view.
post #9 of 15 (permalink) Old 03-09-2012, 05:12 PM Thread Starter
JM2001's Avatar
Thanks for the review. I'm going to place an order for one.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 15 (permalink) Old 03-10-2012, 11:58 AM
2FAS4U
I like to put my GPS in the clear map pocket on top of my tank bag.
Have been through many a rainstorm with it there.
2fas4u is offline
