saddlebag support brackets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-25-2012, 09:18 AM Thread Starter
scuba's Avatar
has anyone ever used these and where do they mount on?
I am looking at these: http://www.ebay.com/itm/180800656408...9#ht_625wt_948
the seller says they mount to the side of the rear fender. I just can't figure out where.
Any input would be much appreciated.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #2 of 9 (permalink) Old 01-25-2012, 10:08 AM
JM2001's Avatar
I think you need the support bracket and mounting loop (?? ) Heres a picture. You can zoom in on the installation
http://www.cruisercustomizing.com/ka.../KAK-53021-094
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 9 (permalink) Old 02-16-2012, 02:44 AM
I have the Kawasaki brackets. Anything else is probably going to require modification. Might be easier to just build your own.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 9 (permalink) Old 02-16-2012, 12:43 PM
Gemguy's Avatar
I have these and they sit behind the bags to keep them from banging into the rear wheel. At $28 I think they're cheap enough that you don't have to make your own since they have the mounts on them and you should see if you can get the long bolts that go with them.
~VROC~ # 389
Gemguy is offline
post #5 of 9 (permalink) Old 02-16-2012, 03:44 PM
Crap, I WAS in 5th gear.
I believe I have the same ones. You will need to grind the weld on the inside, and use washers underneath the boss to get them mounted properly. You could also just use more washers as spacers instead of grinding with your Dremel. You will need LOOOOONG bolts from the hardware store and lots of washers t mount. I would buy them again.
Kelly2001 is offline
post #6 of 9 (permalink) Old 02-16-2012, 10:28 PM
Check out the Willie&Max brackets. They are adjustable. The problem with the Vulcan 750 is that it does not have flat rear fender supports with the 2 bolts that go flat against the support. Both the front and rear bolts are recessed into the fender/seat rail, and the rear bolt is a lot higher than the front. The Kawasaki brackets that are actually made for the Vulcan 750 are designed for a perfect fit, and also relocate the rear signals back to give more mounting room for saddlebags. The helmet locks do have to be removed, and, having a thing for detail, I removed the rails and used a Dremel to completely cut off the mounting tabs and grind everything smooth.
1979 Vespa P200E
post #7 of 9 (permalink) Old 02-16-2012, 10:49 PM
Here are the ones I have. These are made by Kawasaki specifically for the Vulcan 750.
Link: http://tinyurl.com/7ayjo3s
I found some more on eBay that say they are for the Vulcan 750, but do not have the turnsignal relocator brackets
1979 Vespa P200E
post #8 of 9 (permalink) Old 02-25-2012, 01:02 PM
Do I need those saddlebag supports?
Since our weather hasn't been very good for any lengthy rides since I got my 750, I haven't had the need to load my saddle bags with anything heavier than a jacket liner, so I don't know how they'll work when loaded heavier for some longer rides. The bags are Willie&Max soft bags.
Will I need to add the bag supports to avoid problems?
At this point, the bags just need to be sort of tucked in front of the turn signals and I don't find that to be too much of a problem, but will they definitely need to be relocated if I add the bag supports?
I'm not into metal fabrication like so many of you folks are, so I need to have "stuff" that takes a minimum of additional work to make things fit.
WillRose
Standing Proud WA State Patriot Guard Rider
'94 Vulcan 750 & '06 Burgman 650
WillRose is offline
post #9 of 9 (permalink) Old 02-25-2012, 03:06 PM Thread Starter
scuba's Avatar
they fit perfect already installed
vn750.com scuba
1984 kz750 ltd
2002 nomad trike
1978 suzuki 250
1964 harley amf
custom exhaust
custom mirrors
custom grips
custom floorboards
custom exhaust
scuba is offline
