Horns - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 12-02-2011, 12:57 PM Thread Starter
Horns
Many of the horn upgrades are horns that use more power than stock, requiring wiring a relay to avoid burning out your switch.
Saw this on the Feeger forum, a new horn by PIAA that uses the same power as most stock horns. Bolts on the same and uses the same blade connections. Plug and play. You can leave one stock horn and use only one of these:
http://www.compacc.com/p/PIAA-Slimli...s-Horn/1603005
I would guess you could use two also. I think this is a 2 horn kit:
http://www.amazon.com/85114-400Hz-50...2849680&sr=1-2
post #2 of 9 (permalink) Old 12-02-2011, 09:21 PM
This would be a clean looking unit to mount in place of air cleaners after an ear shave. One facing FWD and the other AFT.
Also, I think it would work well on my EX250.
TimV65 is offline
post #3 of 9 (permalink) Old 12-02-2011, 10:21 PM
If only it had 6th gear..
DavesVulster's Avatar
Thanks Knifemaker. This is a decent horn. 112 decibels and the Stebel Nautilus is 115 (at 6ft) so it's a good contender. I wondered about the current draw with an aftermarket horn.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #4 of 9 (permalink) Old 12-03-2011, 12:29 PM Thread Starter
The popular replacements...the Stebel, the Wolo, and the Freeway Blasters all use more juice and require to be rewired with the horn button on a relay. Not a problem to those who know what to do, but a pain for the electronicly impaired...lol.
Many of the horms that don't need the relay are not much louder than the stock units.
These PIAA horns use from 0.5 amp more to 1.0 amp less, making them ideal plug and play replacements..
post #5 of 9 (permalink) Old 12-03-2011, 01:57 PM
I have been looking at these and I like what I see so far,the slim design is biggie for me ,as my stock horns tuck in behind the radiator,good find,KM.
As for the quote ,the db rating is on a logarithmic scale not linear,there is a quite a difference in just a couple of db,but I would say at a guess that our stock horns our stock horns are around 75db (That is what a 500Ninja is rated at) so 112db would be a huge difference over stock.
post #6 of 9 (permalink) Old 12-03-2011, 04:04 PM
Good info. I noticed that stebel's specs say 139db at 4 inches. I wouldn't want to measure that with my ears, no thanks
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #7 of 9 (permalink) Old 12-04-2011, 10:33 PM
flitecontrol's Avatar
Can't find it at the moment, but most independent tests of manufacturer's horn ratings found that they grossly exaggerated their db output. There is no certifying board, so they can claim whatever they want!
IIRC, noise levels approximately double every three db. In other words, 115 db is twice as loud as 112 db.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 9 (permalink) Old 12-04-2011, 10:47 PM
x2 on the independent tests & exaggerated factory claims.
post #9 of 9 (permalink) Old 12-04-2011, 11:26 PM
Wow. Thanks for the info
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
