Toolbox lock replacement. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 10-29-2011, 09:57 PM Thread Starter
Ndr
So, the bike i bought came without a toolbox and I am currently in the process of ordering the pieces to put together a replacement box.
Does anyone have a source for putting in a replacement lock for the box? the prices for a new lock from the dealer seems a bit high. Since I would end up with a second key either way, I was wondering if there was a cheaper alternative to the lock. (such as picking on up from the local hardware store)
What type/style of lock would I be looking for? (I guess its a little difficult searching fora part when you don't know what they are called.)
Ndr is offline
post #2 of 10 (permalink) Old 10-29-2011, 10:53 PM
Something like this:
http://www.eastloc.com/camlock2.htm
Probably can find a drawer lock/cam lock similar to the c57 or 59 above in the local hardware store.
post #3 of 10 (permalink) Old 10-29-2011, 11:38 PM
flitecontrol's Avatar
Home Depot and Lowes have them too.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 10 (permalink) Old 10-30-2011, 09:01 AM Thread Starter
Ndr
Camlock. Got it.
Thanks!!
Ndr is offline
post #5 of 10 (permalink) Old 10-30-2011, 10:13 PM
If you need a toolbox lock, I have a stock one with key.
$20.00 shipped.
RakerBill is offline
post #6 of 10 (permalink) Old 10-31-2011, 10:25 AM
2000 VN 750 Senior Member
I believe there is a older thread on how to rekey Vulcan locks so they match your ignition key. Try the search button at the top.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #7 of 10 (permalink) Old 10-31-2011, 06:18 PM
ifixf18s's Avatar
My toolbox lock vibrated loose and fell off. So when I get a replacement a bit of non perm threadlocker will be used. Just a bit of helpfull information when you replace yours.
ifixf18s is offline
post #8 of 10 (permalink) Old 11-01-2011, 12:41 AM
My first toolbox lid broke and fell off years ago, along with the lock. I replaced both with new oem parts, and learned NEVER to use that box. It is designed to break. Kawasaki engineering at it's absolute worst. I run my seat without the bolts, so I will not have to open that lid to get to them. I have the extended backrest, and it holds the seat in place.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 10 (permalink) Old 11-02-2011, 01:14 AM
If only it had 6th gear..
DavesVulster's Avatar
I used black duct tape on the inside to help support the rediculous plastic hinge. Others have made their own hinges that look cool and work even cooler. I have thumb screws securing the seat so I can remove it without fishing for a wrench. It's worked out for me so far but you have to check the tape every now and then . The Gorilla tape seems more durable by the way.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #10 of 10 (permalink) Old 11-02-2011, 09:34 AM
93VN750's Avatar
Old post of mine, but I am sure parts are still available.
https://www.vn750.com/forum/showthrea...=tool+box+lock
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
