New Grips.. Similar to ISO Grips... install question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 10-24-2011, 08:39 PM Thread Starter
MaDeInSin's Avatar
Hey Guys- I purchased the grips in the link below and received them. The greatly resemble the ISO grips. I have read the verses and done multiple searches and can find anything that helps me totally.
The throttle or right side grip seems to have gone on easily. I removed the old grip by taking out the two screws allowing me to get to the throttle cable. I reinstalled them in the new grip and tightened it all back up. A couple of things. The grips doesn't recoil back like it should now when you give it gas. It seems tight... and during the install i didn't use any glue or hair spray because it seems to me that it needs to spin freely. I have read a lot regarding some "sleeve" but I did not see or encounter one. A sleeve that you need a dremel to shave some parts off?
The left side i have not installed pending some direction. It looks like I just cut the old one off.. Clean the bar... and use some Glue to put this one on?
Thanks guys
Helps appreciated
Jay
http://www.ebay.com/itm/Motorcycle-C...ht_2853wt_1163
MaDeInSin is offline
post #2 of 3 (permalink) Old 10-24-2011, 10:07 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
That's pretty much what I did for the left one.
Dunno about the right though.
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #3 of 3 (permalink) Old 10-24-2011, 10:26 PM
on the Throttle side ,make sure you didn't slide it on the bar too far and thereby letting the inside end of the grip rub on the end of the bars.It looks like the sleeve is already in the grip on the pictures.
