Cleaning Helmet - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 07-10-2011, 07:14 PM Thread Starter
Cleaning Helmet
Just got back from a long ride. 113 degrees out and helmet is soaked. Liner is removable and gonna wash. Cheek pads wont come out, was wondering what people use to clean them.
Halinski is offline
post #2 of 8 (permalink) Old 07-10-2011, 11:16 PM
Concert connoisseur
wib714's Avatar
you mean to tell me you can clean them?
this is 50 miles on my way home at night!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 8 (permalink) Old 07-10-2011, 11:17 PM
Concert connoisseur
wib714's Avatar
and this is not a bad night at all. ive got a couple pics where you cant see through the shield at all.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 8 (permalink) Old 07-10-2011, 11:29 PM
Scootergptx's Avatar
Shout (the laundry stuff) makes sheets to clean stains, you could try that. Or an apholstery cleaner like Tuff Stuff.
Also, when you're done and it dries, rub an dryer sheet on them. Helps with the smell. Keep one in my off road helmets when they sit for long times.
Bonus, you get better looking hair than Flo (progressive chick) when you take the helmet off.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #5 of 8 (permalink) Old 07-10-2011, 11:34 PM
I don't know if you really can, but I am sure drying it out really well will help. maybe some fabreze would help with any residual odor if thats your problem. For actual stains or spots, try the tide pen or an upholstery spot cleaner. The outside is easy, just some water is all you really need. maybe a light dish soap.
post #6 of 8 (permalink) Old 07-10-2011, 11:37 PM
I've used a real weak solution of Dawn detergent and distilled water , using clean paper towels to blot out excess water. I then use some of the distilled water to rinse any soap out...blotting again with the towels.
Make sure to let the helmet air out to dry before using again. (A good case for owning more than one helmet).
Some suggest using Fabrezze? To help de-funkify the inside, but that's your call.
post #7 of 8 (permalink) Old 07-11-2011, 03:13 PM
rev it up's Avatar
LOL,,,thats what my face looks like !!,,,i use an open face helmet.lol.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #8 of 8 (permalink) Old 07-11-2011, 10:08 PM
I've used a weak shampoo solution.
Rinsed it very well.
Then put the helmet over a small fan for a couple of days.
It worked very well and didn't have a strong detergent smell, later.
daffy is offline
