Adding Drag Bars + Risers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-06-2011, 10:28 PM Thread Starter
ryanmitchy's Avatar
I bought a set of 3.5" Rox Risers and a 29" set of drag bars and im probably going to install them this weekend. As someone who doesnt work on bikes often just wondering whos done this and if you have any tips. I've heard its straight forward by unbolting and rebolting back together and i bought new grips for it too. Anyways any info would be a good Confidence booster
ryanmitchy is offline
post #2 of 8 (permalink) Old 06-08-2011, 01:01 PM
before you tighten it all down turn handle bars full lock on both sides to make sure cables and switch boxes dont hit the tank.
qweesy is offline
post #3 of 8 (permalink) Old 06-08-2011, 07:53 PM
balzout's Avatar
Post a pic when your done. would really like to see what it looks like with drag bars.
balzout is offline
post #4 of 8 (permalink) Old 06-08-2011, 08:05 PM
Patriot Guard Rider
The DEUCE's Avatar
The hardest part for me was when the choke cable came apart. Everything else is straight forward. Do you have handle grip glue or are you going to use hairspray?
VN750 #9300 & VROC #33453
The DEUCE is offline
post #5 of 8 (permalink) Old 06-08-2011, 09:40 PM Thread Starter
ryanmitchy's Avatar
was going to buy some handlebar glue., assuming you can get it from any walmart or auto store? Any recommendations on getting old grips off without cutting them?
post #6 of 8 (permalink) Old 06-08-2011, 09:45 PM
Patriot Guard Rider
The DEUCE's Avatar
Stick a long skinny screwdriver between the handlebars and grips and work it free.
post #7 of 8 (permalink) Old 09-06-2011, 06:27 PM
So did you ever do the changes? I'm considering changing grips on mine.
eusjma is offline
post #8 of 8 (permalink) Old 09-06-2011, 07:50 PM
For loose grips.....
Here's an old motocrosser's tip from the 70's....
...a few wraps of quality electric tape (I like the 3M), then a wipe with gasoline....cheap and easy....works like a charm !
