handlebars - mysterious shift - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-06-2011, 09:31 PM Thread Starter
Rider on the Storm
EasyRector's Avatar
Question handlebars - mysterious shift
I keep my handlebars in the standard position, everything torqued to spec.
However, after I while, I notice that my handlebars gradually drop ~ i.e. the grips are closer to the tank, and to my body. I can't physically do this while pushing down on them. They simply seem to move out of position over time.
Is this typical? I'm wondering if it's the wind pressing against my PF3 fairing at highway speeds. Or if it's just the vibration of the bike over time. I'm certainly not putting any massive pressure on the bars with my hands, other than the usual pressing down as I lean into turns.
EZC
EasyRector is offline
post #2 of 5 (permalink) Old 05-06-2011, 09:43 PM
The standard bars have fluted bands that are supposed to help hold them. So I would guess something is loose? Try cleaning them and re-tightening them down.
post #3 of 5 (permalink) Old 05-06-2011, 11:20 PM
Concert connoisseur
wib714's Avatar
I could see where the wind beating on the fairing would do that, I dont have one and mine has not moved. I would think the wind would almost have an effect of an impact wrench over time!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 5 (permalink) Old 05-07-2011, 12:33 AM
Patriot Guard Rider
The DEUCE's Avatar
Bar clamp is either loose or the handlebars are stripped.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #5 of 5 (permalink) Old 05-15-2011, 03:42 PM
vulcan lover/hater
you might try disassembling the handlebar clamps and putting some loctite BLUE (NOT RED) where the clamps tighten down on the bars. I can't imagine anything shifting with that stuff on. And the thing can be disassembled with the blue loctite on it. With the red, you'd need an jackhammer.
Chaz is offline
