All interested in forward controls - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 59 (permalink) Old 05-01-2011, 09:00 PM Thread Starter
Fire Axe Man
Exclamation All interested in forward controls
I have a good start on mine and will be making as many as needed total cost is not finished yet so i don't have a price yet either, way more affordable then jardines though i promise!!! they will bolt on, using your stock foot pegs
For mine i turned the shifter and brake straight down cut them off and hooked linkage to a hole i drilled in the stock levers... trying to buy a machine or tool to "press spines" so you all wont have to do the same...
My goal is to make these so you can all put it back to stock if you choose later...
What i would like is a general idea of who is interested so when i have a total price i have an idea of how many to punch out... if you dont mind cutting stock brake and shift lever as i did would make these cheaper as well... as i'm sure the tool won't be cheap...
Just can't leave well enough alone...
86 vn750
Ears Shaved
Custom Exhaust
Custom Seat
Hardtail 3 1/2" drop rear
Custom turn signals
15" apes
Custom grips
Custom forward controls
Custom paint
many more mods to come
Mike23Impala is offline
post #2 of 59 (permalink) Old 05-01-2011, 09:17 PM
Patriot Guard Rider
The DEUCE's Avatar
Do you have any pictures of what you have done?
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 59 (permalink) Old 05-01-2011, 09:25 PM
I might be interested depending on pirce and general design
post #4 of 59 (permalink) Old 05-01-2011, 10:21 PM
yeah, I'm always interested in something new to bolt onto the Vulcan
dariv is offline
post #5 of 59 (permalink) Old 05-01-2011, 10:25 PM Thread Starter
Fire Axe Man
nothing yet for pics sorry... will soon, and the shifter problem is solved noone will have to cut there stock levers... I was over thinking this simple design and over looked the concept... it will be an easy build...
86 vn750
Ears Shaved
Custom Exhaust
Custom Seat
Custom turn signals
15" apes
Custom grips
Custom paint
post #6 of 59 (permalink) Old 05-02-2011, 02:20 AM
BMan23777's Avatar
Interested!!!!!!
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #7 of 59 (permalink) Old 05-02-2011, 02:54 AM
Journey's Avatar
VERY INTERESTED i am 6 3 and need more leg room
My Enuf.
1995 Vulcan 750
New wires and plugs
Removed and cleaned carbs
re routed air line to right ear
re built transmission
New stator
New RR
New throttle cables
New clutch cable
New wiring harness
New Ignition switch
TIME to Ride
Journey is offline
post #8 of 59 (permalink) Old 05-02-2011, 09:55 AM
JM2001's Avatar
Interested. Will depend on price and how they look
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #9 of 59 (permalink) Old 05-02-2011, 10:31 AM
clock152's Avatar
count me in.
clock152 is offline
post #10 of 59 (permalink) Old 05-02-2011, 11:04 AM
Be True, Be Safe!!!
cheeser's Avatar
Interested as well.
Purchased 5/2010 w/7100 mi. mi
R/R relocate
Spline lube 05/10
After-market Mirrors
Iridium plugs
AGM MF Battery
Tank Bib Courtesy of Achaundy
Saddle Bags
Wolo Bad Boy Air horn
Protac driver backrest
Ccspiner Driver Floor Boards
Pending
Highway Pegs
Luggage rack.
cheeser is offline
