Luggage rack mounting info needed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-19-2011, 01:33 PM Thread Starter
JM2001's Avatar
I'm not installing a luggage rack but I'm doing a modification that if it turns out I'll post a picture. My question is when I look at a picture of the luggage rack it has two ears on it that attach under the seat and I assume screws are put thru the ears and threaded to the plate under the seat. I tried to install 1/8" aluminum plate into the plate under the seat. I beveled the screw holes so the screw heads are flush with the plate. My problem is that the screws thru the trunk do not line up with the seat brackets because of the 1/8 inch plate. How do they get around this problem using the luggage rack ?
Thanks
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 12 (permalink) Old 04-19-2011, 01:55 PM
Senior Lurker
Sloppyburpfest's Avatar
Hey JM2001,
Have a look at this post, it may help you:
https://www.vn750.com/forum/showpost....4&postcount=46
-Sloppy
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #3 of 12 (permalink) Old 04-19-2011, 02:04 PM Thread Starter
JM2001's Avatar
Originally Posted by Sloppyburpfest View Post
Hey JM2001,
-Sloppy
Sloppy, Thank you very much. There is no freaking way my seat would ever fit with the setup as shown. I had to grind down the head of a standard 8mm screw plus bevel the plate to even come close to the seat bracket screws lining up. I'm stumped.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #4 of 12 (permalink) Old 04-19-2011, 02:24 PM
Senior Lurker
No prob, glad to help.
I assure you that on a stock bike, it all fit together just fine, without any modifications needed.
Good luck with your project. -Sloppy
R.I.P. Lance328
post #5 of 12 (permalink) Old 04-19-2011, 02:28 PM Thread Starter
JM2001's Avatar
My bike and seat are stock. Somewhere I have a clearance problem. My project is done other than getting the seat attached to the trunk. I never said this to a guy before but " NICE RACK "
Thanks
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 12 (permalink) Old 04-19-2011, 02:43 PM Thread Starter
JM2001's Avatar
Now I'm talking to myself. If I slide the seat on the bike everything lines up with the trunk screws. I add 1/8 " and nothing lines up. With the Kaw luggage rack it looks like they added about 1/2 inch, ears and head of bolt, and everything lines up. I don't get it.
Off to get a drink. LOL
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 12 (permalink) Old 04-19-2011, 07:01 PM
Where can you find a rack for a 1986 vn750???
honuki850 is offline
post #8 of 12 (permalink) Old 04-19-2011, 07:43 PM
Photos of what you are attempting would help. The stock rack is not a "plate", but carefully bent tubes that end in a thin flat strap. The seat itself can be relieved to fit the bolts if needed BTW... Corbin and Mustang seats usually need this done....stock seat just bolts up fine.
You must have something interfering with the seat.... But again can't help you without photos.
post #9 of 12 (permalink) Old 04-19-2011, 07:44 PM Thread Starter
JM2001's Avatar
Have to get a used one. Here is one
http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 12 (permalink) Old 04-19-2011, 07:55 PM Thread Starter
JM2001's Avatar
Thanks KM. I guess I'll try to relieve the seat above the holes where the bolts would go. Once I get that done and the seat installed I'll post some pictures. It might be a crazy modification but it also might be usefull
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
