Shift Lever Modification Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-18-2011, 10:09 AM Thread Starter
JM2001's Avatar
Has anyone modified or seen a longer rod ( rubber tread covered ) for the shift lever? My big toe is the only part of my foot that hits this rod and it gets very sore after 200 shifts Lol. Seems like it should be about 2 inches longer. Any suggestions.
Jim
JM2001 is offline
post #2 of 11 (permalink) Old 03-18-2011, 10:50 AM
Yahoo VN750 Group Owner
Pick's Avatar
Send a message via Yahoo to Pick
Jim
I don't know about a longer one, but I have the Kuryakyn #4036 Shift Peg Cover (http://www.kuryakyn.com/Products/913/Shift-Peg-Covers) that helps a lot, and looks great, too. I think I had to use a little piece of rubber as filler, but it was easy to install. Just slice off the stock rubber thingy and clamp on the new one. I also have the Kuryakyn #4029 Brake Pedal Cover.
Jim "Pick" Foster
Dixon, IL
VROC #9492
2010 Honda NT700V
http://www.flickr.com/photos/jimfost/sets/
http://s186.photobucket.com/albums/x294/jimfost/
Pick is offline
post #3 of 11 (permalink) Old 03-18-2011, 11:01 AM Thread Starter
JM2001's Avatar
Thanks Pick. I checked out their site and the covers look good. I might try them if I can't come up with something longer.
Jim
JM2001 is offline
post #4 of 11 (permalink) Old 03-18-2011, 05:05 PM
Perhaps you should not wear sandels?
The length of the shift levers "pad" is so you can easily move your toe from under it ...to above it ..and visa versa when shifting gears.
Making it longer would just make your foot do more work. If your shoe is not sturdy enough to handle the shock of moving the lever, you can try padding it with foam, or by using one of these to go over you flimsy shoes :
http://www.allautocenter.com/buy-shu...s-accessories/
post #5 of 11 (permalink) Old 03-18-2011, 06:17 PM Thread Starter
JM2001's Avatar
Thanks. It was only 54 degrees yesterday so sandals were out of the question. I wear soft toe leather boots. Today I went riding again, 50 degrees, and switched rides with a friend who has a 900 Custom. His shifting lever arm was no problem at all. It is 1 inch longer than mine. He did not like my shifter and had the same problem. Both of us have been riding for over 30 years.
Jim
JM2001 is offline
post #6 of 11 (permalink) Old 03-18-2011, 09:10 PM
flitecontrol's Avatar
It's possible that yours is harder to shift for some reason. Mine is easy and smooth. How long since the oil was changed?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 11 (permalink) Old 03-18-2011, 10:37 PM
A piece of old garden hose can do the trick................
post #8 of 11 (permalink) Old 03-18-2011, 11:20 PM
Pick's Avatar
Jim
It's also possible that the bike was dropped on the left side at one time and the shift lever was bent in a little. You might try removing the lever and putting it in a vise and bending it slightly outward. It could help. (I wouldn't recommend trying it with the lever still attached.)
Jim "Pick" Foster
Dixon, IL
VROC #9492
2010 Honda NT700V
Pick is offline
post #9 of 11 (permalink) Old 03-18-2011, 11:28 PM Thread Starter
JM2001's Avatar
Oil is fresh oil, 15-40 weight Rotella T as suggested on this site. Only 90 miles on the oil change. I wouldn't say my bike shifts hard, but not overly easily either. At the farthest end of the lever shaft there is a metal ridge that holds the rubber sleeve on. It has worn a line in my boot in 90 miles because there is not much surface area for my boot and only my big toe area makes contact. I am going to come up with a longer shaft ( 21/2-2 3/4) cut my old one off, and weld on the longer one. I was hoping there was an easier way to go. I do not have wide feet either.
Thanks for the reply
Jim
JM2001 is offline
post #10 of 11 (permalink) Old 03-18-2011, 11:37 PM Thread Starter
JM2001's Avatar
Thanks, It is possible that the shift lever could be bent. It does not appear to be, chrome is like new, no scatches or marks. This is my first Vulcan 750 and I have never ridden another one, so I can't say if the lever is bent or not. The lever arm does not come over the footrest very far, maybe 3/4 inch.
Jim
JM2001 is offline
