Memphis shade wind screen - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-10-2011, 01:06 AM Thread Starter
I found a Memphis shade wind screen on CL, the price was too good to pass up, but it says it is a 9"HDLT fats/slims mounting kit for vn800b classic and vn1500, does anybody know if this will fit an 86 vn750? here is a link to what I got http://www.cajuncycleacc.com/item933.htm
Blue Buddha is offline
post #2 of 7 (permalink) Old 03-10-2011, 03:07 AM
Young Gun
kc_matt's Avatar
Haha, I saw that shield, thought about snaggin it. Let me know if it works out!
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #3 of 7 (permalink) Old 03-10-2011, 08:59 AM
Concert connoisseur
wib714's Avatar
that link is to a hardware kit, dont see no shield though!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 7 (permalink) Old 03-10-2011, 09:12 AM Thread Starter
It is the hardware kit, my bad. But for 20 bucks I felt like it was a steal.
post #5 of 7 (permalink) Old 03-10-2011, 10:03 AM
It's most likley not going to bolt right up but like you said for $20 buck I'm sure you could figure some way to retro fit it.
post #6 of 7 (permalink) Old 03-10-2011, 12:27 PM
the kit wont work for our bike... the vn800 uses 1" handle bars. our vn750 has 7/8" handle bars, so you need to look for a kit for 7/8" bars
Edit, should have looked at it first... the kit might work.. you might have to drill out a couple holes to mount it ... make sure youget the shield at the same time so you can get every thing lined up at once
post #7 of 7 (permalink) Old 03-10-2011, 03:48 PM
flitecontrol's Avatar
Might get by with some spacers to fill the gap between bars and mounts.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
