Joe Rocket "HammerHead" tank bag, GPS, Female cig. power cord adaptor and other pic's - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 02-26-2011, 02:03 PM Thread Starter
Headbanger/Popes of Hell
ruger's Avatar
here's how I use my GPS on the vn750. this is a Joe Rocket "Hammer Head" tank bag. it fits great, as yo can see from the pic. in the top pocket I put the GPS, in the bottom pocket I put the Female cig. adaptor. I run the power cord form the GPS and plug it into the Female cig. adaptor, the adaptor is plugged into the attachment used for my Battery Tender.
ID:	3409   Click image for larger version
ID:	3410   Click image for larger version
ruger is offline
post #2 of 6 (permalink) Old 02-26-2011, 04:26 PM Thread Starter
ruger's Avatar
here's a couple of pic's of the bikes in the garage.
ruger is offline
post #3 of 6 (permalink) Old 02-26-2011, 05:01 PM
Young Gun
kc_matt's Avatar
I'm not particularly a fan of tank bags, but that is an excellent set up you have put together.
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #4 of 6 (permalink) Old 02-27-2011, 12:48 AM
johnm's Avatar
That's definitely the ultimate in simplicity . . . and I love simple.
1989 VN750
VROC#31798
I'm bad with names. May I just call you dumb?
johnm is offline
post #5 of 6 (permalink) Old 02-27-2011, 11:53 AM
Questions...........
Can you see the screen on the GPS under that plastic cover OK with reflected sunlight?
Does the GPS give you voice prompts and how do you hear them?
Assuming it is a touch screen...does it work OK under the plastic?
post #6 of 6 (permalink) Old 02-28-2011, 06:58 AM Thread Starter
ruger's Avatar
I used this set up when the wife and I took our trip down to the "Hills" last Oct., and I will use it again in May. no, I didn't have a lot of trouble seeing it in the sun. from time to time I did have to cup my hand over it to see, but most of the time it was fine.
yes, the GPS gives voice prompts, but I just mute it. I ride with mp3 player going so I don't use the voice prompts.
yes, it is a touch screen and yes, it works just fine under the plastic.
ruger is offline
