Mirror ideas - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-18-2011, 11:26 AM Thread Starter
Papa Smurf's Avatar
Mirror ideas
Well it was finally warm enough to try and JB weld my right mirror back on (about 1 cm of the part the mirror screws into). I didn't like the look of it/trust it so I was wondering: has anyone had success with a bolt on mirror? I am not one for cosmetics; just functionality.
I noticed Emgo makes a $10 one , but I am worried about the clearance between the master cylinder and the handlebar. Not much room there.
http://www.motorcycle-superstore.com...On-Mirror.aspx
Any thoughts? The only other idea I have is to bolt on further down the handlebar (around the crease) and get a longer, flexible/knobby stem to compensate for the weird angle.
Papa Smurf is offline
post #2 of 3 (permalink) Old 02-18-2011, 01:56 PM
Gemguy's Avatar
I removed those big lollypops that were there and replaced them with a pair of small rectangular mirrors that I bought I think from Cheap Cycle Parts for about $12 each and they're fine. Look good and work well. They mounted into the same screw holes where the originals screwed on. The only thing you have to be careful of is that the arms are long enough so you can see past your arms. Otherwise you'll only be looking at your body or off to the side.
~VROC~ # 389
Gemguy is offline
post #3 of 3 (permalink) Old 02-18-2011, 02:08 PM
flitecontrol's Avatar
Since your bracket is broken and you apparently don't want to replace it, it would seem a clamp on or bar-end mirror would be the only other options.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
Tags
mirror
