Kuryakyn ISO grips installing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 11-12-2010, 12:12 PM Thread Starter
Wareagle1970
carolesteven's Avatar
Hoping to install these used grips tonight that I bought from someone on here.
Do any of you have any tips and or tricks for removal of the stock grips and installation of the new ones. I assume the grip with the little tabs on the open end of the grip goes on the throttle side???
Thanks in advance,
Steven
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 17 (permalink) Old 11-12-2010, 01:57 PM
stock grip removal:
1. cut grip lengthwise with razor knife.
2. peel off grip.
3. clean glue residue with prefered solvent.
note: careful not to slice through throttle tube.
post #3 of 17 (permalink) Old 11-12-2010, 02:15 PM Thread Starter
Wareagle1970
Originally Posted by M_Angell View Post
stock grip removal:
2. peel off grip.
Was hoping to keep the stock grips, in case I need them later or someone on the forum needs a set.
Have read that to remove you can pour lighter fluid (I assume the zippo type, not the cooking type)
between the grip and the chrome to loosen it up.
Have seen that Gorilla Glue is also a good glue to put the replacement ones on with.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 17 (permalink) Old 11-12-2010, 03:00 PM
flitecontrol's Avatar
Can also spray WD-40 inside the grip and loosen it up. Another, quick, method is to slip a flat blade screwdriver under the grip, insert a compressed air nozzle, and infleate! Comes right off.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 17 (permalink) Old 11-12-2010, 03:38 PM Thread Starter
Wareagle1970
Have heard that works. I'm just trying to imagine what the throttle side looks like under the grip? Would it hurt to spray WD40 under that side as well?
Also, can I use Gorilla Glue to reinstall?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #6 of 17 (permalink) Old 11-12-2010, 05:02 PM
I haven't had mine off, but from the pics I've seen of the throttle side, it's just a thin sleeve the grip slips over. Either method should work well on both grips.
I would not use Gorilla glue! If you ever want to get that puppy off, it ain't comin' without a saw or grinder involved. Have heard a lot of folks recommend hair spray. Lubricates to help installation, holds it when it's dry, and isn't too hard to remove.
"Black Beauty"
Old Blue
post #7 of 17 (permalink) Old 11-12-2010, 05:27 PM Thread Starter
Wareagle1970
Have decided not to risk it, and just drop by a cycle shop this afternoon and pick up some grip glue...
Kuryakyn ISO Grips
coastered
Hickory, NC
post #8 of 17 (permalink) Old 11-12-2010, 05:44 PM
No one wants the stock grips man.....cut them off....
post #9 of 17 (permalink) Old 11-12-2010, 05:58 PM Thread Starter
Wareagle1970
But then I won't be able to break out my compressor : )
Kuryakyn ISO Grips
coastered
Hickory, NC
post #10 of 17 (permalink) Old 11-12-2010, 06:59 PM
fergy's Avatar
razor knife gets my vote too. Once you go Kury, you never go back. I used golf club tape and solvent to install mine. But the grip glue would be your best bet.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
