Buying cold weather gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 10-07-2010, 06:38 PM Thread Starter
I know there are quite a few threads on winter gear ....like this one:
https://www.vn750.com/forum/showthrea...ht=Winter+gear
Do to the drop in temps I though it might be a good idea to give a few suggestions on what to look for when shopping for colder weather gear. Temps here in STL have been hitting the upper 30's in the morning and getting to the mid to upper 60's durring the day. Perfect riding weather.
I know many say that summer is the time for bikes, but really, many times it is just too damn hot , which makes wearing any protective gear a comprimise between sweating and possible bleeding.
But when the temps hit the mid 50s to 60's...one can wear their heavier gear and not feel like their boots are filling with sweat.
I know alot of riders won't ride in the cold only because the one time they tried it....they just had the wrong clothing on. That down parka you got may work well for standing in line in the cold, but is really useless on a bike. It flaps in the wind, just like those pants you got, and when on the bike, this flapping around causes the jacket and pants to act like a set of bellows...effectively pumping in cold air.
Bike jackets should be fairly stiff...that is the 2nd reason why leather has been the go to material...heavy leather does not "flap" so easy...unless it is too big for you to start with. Textile jackets should have cinches on the arms to take up any slack in the sleeves so they won't flap in the wind. Cold weather gear should feel stiff and heavy. Cuffs should have velcro to tighten them up, and the neck holes should be tight but not choking.
Alot of jackets come with a liner...but avoid the ones that are just thin vests. A good liner should have sleeves, and be fairly warm just by itself. (Wear one around the store and see if you start to get hot)
Most jackets now have some kind of water proof layer...Gore-Tex is the big buck one, but many simular materials do the same thing for less money. Be sure to find out if the garment is "waterproof" and not "water resistant".
Also make sure the waterproofing is in the jacket and not the removable liner, as you might find yourself leaving the liner out on warmer days. Zippers should have velcro flaps. ...not just "waterproof zippers".
You do not need to have a "waterproof" jacket to be warm on a cold but dry day....but I have found that jackets that are also waterproof , tend to be warmer to start with....they just must put more effort into making them air tight...as air leaks can can still pump out warm air and pull in cold air.
Guantlet type gloves help seal out wind from sleeves, and those with a cinch cord to tighten them to your jacket are what to look for.
Pants should folllow the same guidelines as jackets, they should not flap in the wind much....heavy cordura with adjustable cuffs are what you want. Right now I am wearing some tourmaster pants with the liner pulled out...and use them as overpants ....as my work pants are thin. Look for pants that zip to the jacket in the back. ( And yeah, you can't zip them together after you put them on...I provided my wife some entertainment attemping this.....lol...you have to zip them together first then put the pants on...then the jacket)
One issue with those with foreward pegs or controlls ...you don't want air running up your pant leg. Some pants will fit pretty tight around your boots...but still ride up on you. Cruiser bikes tend to have your feet out in front of you anyway...so find a combination of pant/boot that avoids letting air up your leg or makes the pants ride up.
I really can't stop saying how nice the Pinlock visor is. Even in close to freezing weather, my faceshield refuses to fog up. The only bad thing is they are only available for certain helmets....Arai ,Simpson ,Nolan, "big name brands" it seems...... but worth the expense do get one that works.
As being able to avoid letting in cold air to stop fogging does keep your face and head warmer.
If you are to try on any jacket, make sure to wear the layers you plan on wearing. Same with pants, try them on with the liner and your long-johns and street pants. I have a real nice leather jacket that I got at a closeout for a ridiculous price...only problem is, it is real tight with a heavy sweater, so can't wear it in the cold..
Anyway, welcome any reviews of gear or comments on what works for you.
post #2 of 23 (permalink) Old 10-07-2010, 10:26 PM
Bronson's Avatar
Wink
Hi Knifemaker:
I ride in the 30's every day now in the morning. I have a long sleeve T shirt, an oxford shirt, and either my Scropion textile jacket and liner, or may leather jacket, gloves, jeans, and modular helmet on. A scarf is a bonus item, as the only cold spot for me is the neck above the collar and below the helmet.
I love the clear crisp morning ride. I leave home about 05:30 and the ride is about 24 min. I do get some visor fogging at stop signs, but no big deal. Gauntlet gloves are a major plus for cold weather.
It sounds like you have a good choice of equipment for the weather. Others will appreciate your input. A cold miserable ride can really turn one off on the prospects of cool season riding, but it is possible to be quite comfortable in the cold.
Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #3 of 23 (permalink) Old 10-08-2010, 01:24 AM
I`ve no experience with it, but I`ve heard of a neck gaiter made of something called "turtle fur" that is suposed to be very good.
post #4 of 23 (permalink) Old 10-08-2010, 01:37 AM
Daily rider
ksmnet's Avatar
Good info, KM. You have to try out different things and see what works. One thing may be good for a 10 or 20 mile trip, but let's say you're driving from the U.P. four hours in the 28 - 30 degree weather. After awhile the cold penetrates just about everything. I wear long johns, my regular street clothes, insulated ski bibs, insulated chaps, a lined windbreaker (with thick stand-up collar), my heavy leather lined motorcycle jacket, and the cold still penetrates all of it to where I'm not really freezing, but not real comfortable, either. I went to a snowboard cuffed mitten that draws tight over my cuff, but they're still not warm enough for my fingers. On my last ride down (Monday) I had to stop and buy some hand warmers to put in there as well. Kept the fingers from freezing. I wear heavy leather shoes or boots with zip-on rubbers to keep my feet warm (and dry if I hit rain). On warmer days I wear a 1/2 helmet, but in the cold it's a full-face for warmth.
Cold or warm, I love riding. When my iPod is working the long weekly commute goes by a lot better.
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #5 of 23 (permalink) Old 10-08-2010, 01:39 AM
Ceal's Avatar
Every year in winter, a LOT of bikes show up in the local ads (and not so local ones). I wanted to have my bike fixed and sold before this, but looks like it'll have to take another year lol. You can get some awesome deals in winter! Which means a lot of people have no idea what they should wear to ride in winter.
I don't have winter gear myself, but then again, I need to finish fixing up the bike first. It's definitely nice to read such suggestions for when I do buy the gear. Thanks!
Ceal is offline
post #6 of 23 (permalink) Old 10-08-2010, 01:46 AM
cglennon's Avatar
KM's original post link contains my original recommendation, but I'll give it again; grip heaters with a heat-troller. I use them year round here in Portland, OR, even in the summer. I don't even own a pair of winter gloves, but ride year round (use my spring/fall gloves in the winter). The only problem with this setup is when stopping for an extended period (i.e., lunch). The grips take a few minutes to warm up, so my hands might be a bit cold for those first few miles after starting the bike. I will also add that a heat-troller is a must with heated grips, worth every penny.
Chris Glennon - Portland, OR
cglennon is offline
post #7 of 23 (permalink) Old 10-08-2010, 09:06 AM Thread Starter
Originally Posted by cglennon View Post
KM's original post link contains my original recommendation, but I'll give it again; grip heaters with a heat-troller. .
I'll go you one better....heated gloves. You can move them from bike to bike easier, they also keep the back of your hands warm, and ...you can take a hand off the bars on a long trip and your hand doesn't start to get cold. So I would reccomend heated gloves over heated grips.
Another suggestion is to install handguards. I use a set made for the V-strom...have seen some marketed for dirt bikes that would work to. The idea is to get the oncoming air off your hands. Even the PF3 with it's "wings" is not close enough to block the air off the grips.
Wearing winter gloves and using the guards I have no issues till around the mid 30's, and that is only on a long ride.
Be carefull stacking up heated gear. The Vulcan only has about 70watts of usable power, so heated gloves alone should not be a problem...but using them with a heated jacket might.
post #8 of 23 (permalink) Old 10-08-2010, 10:01 AM
flitecontrol's Avatar
Got mine (think it was called a fleece neck warmer) from WalMart last fall for $3. Last one in stock and it absolutely keeps the air out. Think someone here recommended it.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 23 (permalink) Old 10-08-2010, 10:15 AM
baldy's Avatar
If I ever had to use a helmet here I just use my Baklava otherwise known as head condom. lol It has a fleece section that covers from the nose and goes down into the jacket. I might add that when it gets to the point of needing a helmet it is time to put the bike up and get the snowmobiles ready. I'm a risk taker but after the first snow and all the road salt and sand on the roads isn't good for 2 wheels. Well unless your on a dirt bike. haha
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #10 of 23 (permalink) Old 10-08-2010, 12:01 PM
Keyman's Avatar
I go as late into the season as possible. If there's no snow yet, Then I'm takin' the bike.
Today it got down to a cool 38, I was wearing: Leather jacket, Leather pants, Gauntlet gloves, Leather Neck warmer (****ie), Full face helmet W/Breather box And I had my Hot Grips going. When colder temps are expected, I'll just add some layers. Long johns, fleece liners, leather bandanna and so on. Last year on some very cold mornings; I would watch the vapor from my breath turn into ice crystals on my visor. A couple of times my whole visor would slowly crystallize except for two little spots. The two little spots were defrosted by the heat escaping from my eyeballs!
"Ruby" 1994 VN750
Purchased May of 2010 w/576 miles
Highway pegs
Cruise control
Rear turn signal relocation
Viking Saddle bags
Saddle bag supports
Chrome "Vulcan" oil cap
Chrome "K" Brake res. cover
Front tire:110/90-19 K673
Back tire:170/80-15 K673
VN750.com Grille Cover
Spline lube 8/8/10
Hot Grips, Heat-Troller & Relay
Irridium plugs DPR7E1X-9
Clock/Volt/Temp
Keyman is offline
