Custom floorboards install - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 30 (permalink) Old 06-28-2010, 11:24 PM Thread Starter
The floorboards are finally installed..... I used 1/4" aluminum diamond plate to make the boards. They are attached with 1 1/4" stainless flatheads (1/4-20) with a washer and a nut on the back side. The original mounting holes had to be drilled out a little bit to fit the 1/4" bolts.
dariv is offline
post #2 of 30 (permalink) Old 06-29-2010, 02:04 AM
cool boards,might get a little slick when wet though,maybe some strips of nonskid tape would help and still give the diamond plate look a chance to shine too,And I see it is one of the fast ones too. A blue and silver 92 model
post #3 of 30 (permalink) Old 06-29-2010, 02:48 AM
KIMMERLING's Avatar
those look fantastic. Can you apply some type of air cushion to reduce vibration and fatigue?
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #4 of 30 (permalink) Old 06-29-2010, 07:11 AM
very nice boards... are you going to be making a set for the passenger as well?
post #5 of 30 (permalink) Old 06-29-2010, 08:31 AM
CLARK47's Avatar
Very nice, I love the dimondplate. As an all weather rider my second thought was the slipery when wet factor. Maby just a 1/2 border of some roll on truck liner (rino ?) might do the trick and still keep it lookin great.
Agin Love them!!!
CLARK47
1,200 MILES WHEN NEW TO ME
JULY OF 2006
24,000 AND COUNTING NOW
ALLMOST ENTIRLY STOCK
CLARK47 is offline
post #6 of 30 (permalink) Old 06-29-2010, 02:00 PM Thread Starter
I'll have to get back to you about the slippery when wet.....
I've had a few people say "oh, you got the fast one" No idea what you all are talking about here....what's the diff?
humm, never thought of that...I'm sure you could sandwich something in between the board and the casting.
I'm going to try!
dariv is offline
post #7 of 30 (permalink) Old 06-29-2010, 03:44 PM
Columbus, Ohio
jimkonst's Avatar
COOL!
Are they buzzy at all? Would rubber washers fix that if they were? What mods to the foot peg had to be done? Is the peg under there or was it removed?
Is there a reason they don't project further forward? It looks like there is plenty of room for your boot under the shift lever.
Has anybody ever made a right angle lip at the rear of the board to keep your heel from slipping off the back?
Thanks
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #8 of 30 (permalink) Old 06-29-2010, 06:51 PM Thread Starter
Originally Posted by jimkonst View Post
COOL!
Buzzy...no they don't make a sound or vibrate at a high frequency....
I guess a rectangle piece of rubber between the board and peg boss might work....dunno.
The foot pegs are attached to what I call the 'peg boss' by two bolts that come up through counter sunk holes in the boss and screw into the bottom of the rubber part you put your feet on. (there are metal 'nuts' molded into the underside of the rubber pegs) so the rubber peg is removed leaving the cast aluminum boss attached to the bike. I used 1/4" bolts because that is what was available to me at the time..... I would have used metric bolts, but didn't have the right length. (remember if you do use metric flatheads that they are 90 chamfer, not 82).... anyway, the holes in the boss need to be drilled out a little bigger..... I used a unibit and just went to the next size up (9/32 I think?) The casting drills very easy and fast, so be careful. I then just bolted the boards down with flatheads, washers, and nuts.
They could maybe go about an inch further forward I think....the limiting factor, I believe, is the brake peddle.
dariv is offline
post #9 of 30 (permalink) Old 06-29-2010, 07:08 PM
Columbus, Ohio
jimkonst's Avatar
Thanks.
I went to Kanuck 69's series of pics and saw how he did his. Seems similar to what you describe. I should have looked, first.
My concern is for too much flexing and too much leverage on the rear portion. Most folks say that that is not an issue, though.
Jim
Sold my Vulcan
jimkonst is offline
post #10 of 30 (permalink) Old 06-29-2010, 07:11 PM
[QUOTE=dariv;141685]I'll have to get back to you about the slippery when wet.....
I'm going to try![/QUOUTE
just kid of a running joke on here about which color is fastest,naturally I would say blue and silver 92,since I own one too LOL
