looking for the backrest lockbox - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 02-25-2010, 04:56 PM Thread Starter
i just bought my bike and the door is missing off the lockbox on the backrest, if anyone has one lying around or knows where i can get one that would be a great help. i have been looking for one for about a week now and can't find it anywhere.
thanks guys
tim
tkrenz is offline
post #2 of 11 (permalink) Old 02-25-2010, 10:27 PM
Welcome. That is a common problem with the Vulcan 750, due to very poor design. It is not cheap to fix. You will need the toolbox front assembly, $43.75, and a new lock assembly with keys, $69.84. The new keys will not match the other locks on the bike unless you have it rekeyed. I would rather carry 2 keys. But the problem is, it will break again. When mine broke the first time, I caught it before it fell off, and saved the lock. I replaced the tool box cover, but no longer use it. It is designed to break. It might be a good place to keep your registration and insurance stuff, but don't open and close it on a regular basis. You can get the parts from your dealer, or www.bikebandit.com. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 11 (permalink) Old 02-25-2010, 11:48 PM
I've made a custom cover that locks on. I'll see if I could find the old thread I posted it on. I might be tempted to make another one.
post #4 of 11 (permalink) Old 02-26-2010, 12:01 AM
There are other options tkrenz. We do have a Sell or Swap forum where this thread should actually be. Their may be a member who has an extra one to sell.
There is also a direct link to vn750 parts on ebay without leaving this forum.
A member here made his own replacement a few months ago, and posted pics of the process. (EDIT. - see shark88 above)
Quite doable if you are DIY guy.
If/when you get a new plastic toolbox, reinforce the plastic hinge with duct tape or a short piano hinge and a few short bolts and nuts.
You can get a new cabinet lock at any building supply or hardware store for just a few dollars:
https://www.vn750.com/photopost/showp...to=330&cat=505
Use a bit of silicone chalking or rtv sealant on the lock, to keep it from coming loose, and falling off.
More info From the Vulcan Verses.
Toolbox
Q: accidentally leaned on the rear tool compartment door and it broke off. Wonder how much it will cost to replace?
A:You might be able to fix it yourself. Go to a hardware store like Home Depot, Lowe's or whatever you have in that area. Look for piano wire hinges. They do come in various sizes and lengths. They are easy to cut down to the length needed. If you don't want screws showing from the outside, try using industrial type glue, Liquid Nails, Gorilla Glue, silicone adhesive, anything in that line. I'm not sure of the price of the hinges but I know it has to be cheaper than a new box.
You would have to use extra washers or something under the hinge to get it to the level of the edge..sorry...forgot about that...don't have my box anymore to look at...lol A strip of plastic/wood could be glued there (on the inside) to allow the hinge to be flat with the broken edge. just drill the holes through that also to mount. Knifemaker
Bob, the part number is 32098-1057, and www.ronayers.com has it for $29.24 (+ $7 shipping) if you want the OEM replacement
If you do purchase a new one, before you install it, take a piece of duct tape and apply it to the inside of the cover. This will prevent the hinge from breaking and if it does, you will not loose your door and the expensive lock. The duct tape thing works great on older hinges too. Saved my lock twice in the past 8 years... Evan Breyn ~ The Bulldog
Gypsy has a pic on her site where she took a drill and drilled about 4 holes on each portion of the toolbox and used zip ties to hold it together. As long as you do not get them too close to the end to cause the plastic to crack your ok. She did this process, I believe after the box had snapped.
I hope this gives you a few ideas for ways to fix this yourself on a budget, and stay away from Ma Kawi`s stealerships.
post #5 of 11 (permalink) Old 02-26-2010, 01:26 AM
then there is the Stainless Steal option... just look a few threads down from this one
post #6 of 11 (permalink) Old 02-26-2010, 08:53 AM Thread Starter
thanks guys that is very helpful, sorry about the misplaced post. as i was reading this i thought that it might be cool to make one out of diamond plate so that it's nice and strong.
tkrenz is offline
post #7 of 11 (permalink) Old 02-26-2010, 09:37 AM
some SS diamond plate would look nice
post #8 of 11 (permalink) Old 02-26-2010, 10:44 AM
Anyone who goes the route of stock, dealer replacement has never been to this site.
Besides being a total rip-off, like ya said, it'll eventually just break again.
Buy used for cheap or build your own!!
post #9 of 11 (permalink) Old 02-26-2010, 11:53 AM
I agree the stock lid is probably the dumbest thing on the bike, and totally unusable in stock form. I replaced mine with a new one a long time ago when it broke, still had the lock, that made it look right again, and I just never used it. On my '93, I didn't even put the bolts in the seat, because back in the days before MF batteries, you had to remove the seat every couple of weeks to check/add water top the battery, and that meant opening the door every time. It obviously would not last long that way.
I am currently trying to figure out a way to eliminate the box altogether, but I can't use a bag like I've seen others do, because it sticks out too far. I have a luggage rack, and use a T bag on the backrest, which sits on the rack.
I also don't want whatever I do to look homemade. I can easily design something that will work, I just can't manufacture it without some equipment I don't have. Whoever made those radiator grill covers should be able to do it. Jerry.
1979 Vespa P200E
post #10 of 11 (permalink) Old 02-27-2010, 07:45 AM
take a drawing, or even the tool box into your local Community College and have one of their students cut it out for you on a CNC Machine. or better yet since you are in Phoenix Area... stop by Arizona Automotive Institute and have someone in the fabricating classes design something for you and build it for you... It helps them get a good grade, supports their design classes, and would only cost you the cost of materials. Its a win win situation.
