Saddlebags - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 01-17-2010, 08:54 PM Thread Starter
fred's Avatar
Saddlebags
I'm looking to put saddlebags on my bike. I have dual pipes on the right side. Can anybody tell what size will work......or how to measure for bags....Thanks
'90 vn750 9/18/09 15,190 miles
slimstreamer spitfire windshield
AGM battery
OEM crashbar
8mm spark plug wires
removed epa "BS"
fred is offline
post #2 of 8 (permalink) Old 01-17-2010, 11:14 PM
dirtrack650's Avatar
I suggest you get the largest ones that will fit. It's worth it to have the extra space.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 8 (permalink) Old 01-18-2010, 05:37 PM
VN750_DawgsFan's Avatar
As far as depth, I would make sure the bottom of the bags is a few inches above the exhaust on the right side.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #4 of 8 (permalink) Old 01-18-2010, 07:51 PM
Here is a link to an install picture fest for the Mutazu hardbags.
https://www.vn750.com/forum/showthrea...bags+installed
The GA bags that sloppy has on, are the widest bags, (7 1/2") for this height (12+")and length (17+") in the Mutazu line. They do have bigger bags, but may look too big on the vn750. Mutazu has universal mounting brackets available for about $30, IIRC.
Follow this link to Mutazu`s site and look at their installation directions.
http://www.mutazu.com/images/hard%20...20Pictures.pdf
If you are a DIY guy , you may have some steel strap around and can fabricate your own for less.
If you are looking for cheap softbags, or fancier leather ones, try the search feature at the top of page.
post #5 of 8 (permalink) Old 01-19-2010, 12:18 AM
I tried several styles and sizes of saddlebags, and could not find anything that fit the way wanted them too. So I finally pulled out the Mastercard, bit the bullet, and bought the Kawasaki Fire and Steel bag mounts/turn signal relocators, and got the Auburn leather bolt on leather saddlebags sold through Kawasaki. They have been on the bike since '92, and still look like new. I got both the bags and the brackets from an online dealer and saved several hundred $$$$ over what the local stealer wanted. Considering how good they look, and how well they have held up, I think they were a pretty good investment. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 8 (permalink) Old 01-22-2010, 12:40 PM Thread Starter
fred's Avatar
Thanks everyone for your replies. Very helpful. I especially liked the turn signal relocation brackets that were in pictures. Does anyone know where I can get a set?
AGM battery
OEM crashbar
removed epa "BS"
fred is offline
post #7 of 8 (permalink) Old 01-22-2010, 04:11 PM
I believe if you read sloppys thread, that he used the same Kawi- Fire and Steel saddlebag mounting brackets and signal stalk relocation bracket that Jerry did. (~ $130, IIRC) It is all one set, I think.
lance 328 also has a custom signal relocation bracket.
Knifemaker has a diagram on flicker or photobucket for making them yourself. Just find one of his posts and click on the links at the bottom.
Spend a little time with his pics. You will likely find something else there you want to add too.
post #8 of 8 (permalink) Old 01-22-2010, 04:12 PM
Lance makes a set, and you can get a chrome set with the Kawasaki Fire & Steel Saddle Bag Supports... I just saw a set on eBay
