Triplight Magnet - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-16-2009, 05:56 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
Triplight Magnet
Can anybody tell me if those magnets you hook to the bottom of the frame work? They are supposed to cause triplights to recognize bikes. I found a ten dollar one and a twenty five dollar one, and want to know if they are worth the money.
Jim
jimkonst is offline
post #2 of 7 (permalink) Old 10-16-2009, 07:59 PM
I don`t think they are worth the money, but read this from the verses. https://www.vn750.com/forum/showthread.php?t=1126
Look for the cuts in the road where the wire is buried, then sealed over with tar.
Stop with your front tire right over the cut along the left side, and align the wheel with it. It gets the most mass of metal closest to the electrical field sensor.
You could try pushing your kickstand down close to the cut marks too, if the front wheel doesn`t work.
post #3 of 7 (permalink) Old 10-16-2009, 08:22 PM
Jim
Go ahead and buy the 25 dollar one. That's your penalty for the double post....LOL
Seriously, I think they are a waste of money.(I also think adding a magnet in front of your rear wheel is asking for it to "stand up" a nail in the road for your tire to run over) ..
If you can see the "Cut" in the road where the sensor loop is, just pull your bike right over it, this seems to work 90 percent of the time. If you can not get one to trigger, call your local department of transportation and report the signal. They can send someone out to adjust it so it will trigger easier.
post #4 of 7 (permalink) Old 10-16-2009, 09:34 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
I didn't think about using the kick stand. I'll give that a try. The rest I have done. The links sugest attaching metal weights to the frame. My bike is heavy enough.
Thanks, Jim
jimkonst is offline
post #5 of 7 (permalink) Old 10-17-2009, 01:11 AM
stohlbet's Avatar
They work but only on certain lights... I used earth magnets but certain intersections with the camera sensors are hopeless.
stohlbet is offline
post #6 of 7 (permalink) Old 10-17-2009, 02:49 AM
Jace Bror's Avatar
Thanks, Jim
Just make sure you put it back up before you take off...
I don't worry bout lights. I don't know bout other states, but in MN if you have waited a 'reasonable' amount of time you can run it. I forget the name of the law. So I usually just run them after stopping. After I look for cops.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #7 of 7 (permalink) Old 10-17-2009, 08:33 AM Thread Starter
Columbus, Ohio
jimkonst's Avatar
The logic is that the light is defective if it won't recognize your vehicle, and a defective light is treated as a four way stop. Of course, the biker is the only one there who knows that it is defective, so I wait and run it, or if somebody is behind me, I wave them closer, to trip it. But you might still have to go to court to prove your case.
Most of the sensors I come across are set wrong. Especially the one that lets me out of my neighborhood. I don't understand why the DOT won't adjust them. The lights are capable of recognizing bikes...even small bikes.
The logical conclusion is that the DOT does not recognize them.
Jim
jimkonst is offline
