Crack in F&S saddlebags - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-17-2009, 01:43 AM Thread Starter
Send a message via Yahoo to Mr_Grimm
Bullwinkle's sending these bad boys to my Deuce! I just wanted to repair that crack like it was never there! What are your suggestions? I don't know if they are fiberglass or ABS plastic. The crack is epoxied on the other side so it's weather tight. THANKS GUYS and GALS!
http://s197.photobucket.com/albums/aa70/AK82kz440/
Mr_Grimm is offline
post #2 of 4 (permalink) Old 09-17-2009, 04:51 AM
The Professor
lance328's Avatar
You will need to v out the crack from the top with a dremmel and epoxy for a proper repair. Sand smooth and use bondo or metal glaze to fill any low spots. Prime, sand and paint complete cover.
If it is black ABS plastic make sure you you use an epoxy for ABS.
Where are you in GA?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 4 (permalink) Old 09-17-2009, 04:39 PM Thread Starter
I'm in Dalton, Georgia. How can I add that to my profile? I am probably 35 minutes south of Chattanooga, TN. Buford ain't all that far away! Looks to be about 98miles? I may need to look you up! Ya'll can always find me on facebook! I am Zach Poarch. I'd love to get connected with local or semi-local Vulcan owners! My baby is an '87.
I am not sure if these will be fiberglass or ABS plastic. I will have to have them in hand to find out. I have a dremel and several attachments. I am SO eager to fix these bad boys up! It's easy to make JB Weld epoxy smooth with a thumb and some water. I think i'd need to do it in layers if I have a lot of crack to fill so that it will dry/cure well? It's been a while since I worked on anything with epoxy. It gets easy for me to mold as it starts to get tacky. Thanks for the input!
Mr_Grimm is offline
post #4 of 4 (permalink) Old 09-17-2009, 04:53 PM
flitecontrol's Avatar
Click on your site name, then click on user cp on the upper bar, click edit details from the list on the left side of screen, scroll down and add your location where prompted. Then hit the Save Changes button.
Or, maybe that won't work, because I'm technologically challenged. But I think it should.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
