Engine guard bar - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 08-28-2009, 03:34 PM Thread Starter
Reiki3's Avatar
Unhappy Engine guard bar
I got an engine guard and the small bar that connects the upper right side to the frame didn't come with the guard or the hardware for that matter. If someone that has a Kawasaki EG could tell me what the length is and center distance from hole to hole is, I can see about getting one fab'ed up. That way I can turn this boat anchor into an EG.
2000 VN750
gray and black
13,265 when I picked it up
Relayed coils
Volt meter (Relayed)
Blue accent lighting
Iridium plugs
Turn signal buzzer
Highway pegs
Heated grips
Fork bag
Auburn leather saddle bags
Clock
Replaced front side reflectors with LED reflectors
Added LED lights to bottom of front tubes
Polished front tubes
Sylvania H4ST
DEKA MF AGM ETX15L
Regapped pickups to snug .020
TOC ACCT springs
Reiki3 is offline
post #2 of 15 (permalink) Old 08-29-2009, 08:32 AM
Krazee-Krakker
I think it's 2" on center, at least that's what I made my brackets for my highway pegs. Hope that helps
krazee-krakker is offline
post #3 of 15 (permalink) Old 08-29-2009, 10:23 AM
flitecontrol's Avatar
This is the best I could do without removing mine:
1/4" thick chromed steel flat stock
4 1/4" long
1" wide
Holes 3" center to center (not sure what diameter the holes are)
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 15 (permalink) Old 08-29-2009, 09:40 PM
The Professor
lance328's Avatar
4.50" x 1.00" x .250" flat bar
3.50" center to center for mounting holes
guard hole is 1/2"
mount hole 3/8"
Measurements were taken with bracket off.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 15 (permalink) Old 08-29-2009, 10:27 PM Thread Starter
Reiki3's Avatar
Thanks guys, you saved me a ton of work. I was able to get a peace of 4142 chromemoly the make it. It won't be chrome like I wanted but I'll polish it the best I can and it will have to do. At lest I can get it done this weekend and thanks again. When I tell a newbe that this is the best bunch of people you could meet, now this is what I'm talking about.
2000 VN750
gray and black
Relayed coils
Iridium plugs
Turn signal buzzer
Highway pegs
Heated grips
Fork bag
Clock
Sylvania H4ST
DEKA MF AGM ETX15L
TOC ACCT springs
Reiki3 is offline
post #6 of 15 (permalink) Old 08-30-2009, 12:56 AM
The Professor
lance328's Avatar
The ends have a radius. Chromemoly will rust, use SS or Aluminum. I have 6061 T651 Aluminum and can make one if needed.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 15 (permalink) Old 08-31-2009, 02:45 PM Thread Starter
Reiki3's Avatar
https://www.vn750.com/forum/picture.p...&pictureid=696
Lance, I kind of thought it would rust but that’s all I could get. What I did was like who I did the bottom tubes. 150, 320, 600 then 1500 grit then polish. Not the tubes but I did spray the bar with a clear coat to try and keep it from rusting. I laid it out 3.500 between holes and 4.500 long with a full radius on both ends. I don't know if this guard is bent or not, but when I mounted it up the top of the guard comes right at the bottom of the .500 thru. hole in the bar. I have to undo the two top bolts and loosen the bottom ones and then rotate it as far as I can forward to get the radiator cover on and off. Is that what has to be done to get it the cover on and off you’re bike?
2000 VN750
gray and black
Relayed coils
Iridium plugs
Turn signal buzzer
Highway pegs
Heated grips
Fork bag
Clock
Sylvania H4ST
DEKA MF AGM ETX15L
TOC ACCT springs
Reiki3 is offline
post #8 of 15 (permalink) Old 09-01-2009, 01:54 AM
The Professor
lance328's Avatar
You have the bracket mounted in the wrong place, it mounts to the bottom engine bracket mount bolt and the left mounts to the top. You have to remove the exhaust then install the guard. Then remove the guard leaving the bracket on the frame. Install the head pipe and guard.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #9 of 15 (permalink) Old 09-01-2009, 12:10 PM Thread Starter
Reiki3's Avatar
Lance, I think you’re mistaken on the upper hole. I went right by the instructions and it goes in the bottom engine mount hole. If I put it in the top hole it would make it even shorter between holes. The way you put the dimensions (3.500 and not 3 1/2) I know you know your way around measuring instruments. So I don't think you made a mistake in the readings. That is why I was wondering if it might be slightly bent. I'll have to find out what the measurment is between the right side lower mounting hole and the center of the right top tube is.
https://www.vn750.com/forum/picture.p...&pictureid=697
The top left fits up to the upper hole. Can you see how close it fits the the radiator cover. Thats why I will have to undo the top and losen the bottom bolts ane rotate it forwards to get the cover off to mount the cover we should be getting this week.
https://www.vn750.com/forum/picture.p...&pictureid=695
2000 VN750
gray and black
Relayed coils
Iridium plugs
Turn signal buzzer
Highway pegs
Heated grips
Fork bag
Clock
Sylvania H4ST
DEKA MF AGM ETX15L
TOC ACCT springs
Reiki3 is offline
post #10 of 15 (permalink) Old 09-01-2009, 06:38 PM
The Professor
lance328's Avatar
You are correct, meant the bottom hole. I took a measurement from the bolt hole to the bottom mount and it is 4 5/8" C to C, same as the left. What does yours measure?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
