Mounting saddle bags - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 07-27-2009, 08:26 PM Thread Starter
CLARK47's Avatar
'05 750 i havethe bags i want but the hardware i have wont go on with the helmet locks on both sides, is there any way to go around them or how do i take them off?
CLARK47 is offline
post #2 of 12 (permalink) Old 07-28-2009, 04:29 AM
The Professor
lance328's Avatar
Open the lock and remove the screw.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 12 (permalink) Old 07-28-2009, 07:53 AM
Ya may need an impact driver to get the screw to break loose, seeing as the factory puts thread lock on the screw.
post #4 of 12 (permalink) Old 07-28-2009, 12:37 PM
You can also go with the Kawasaki Saddle Bag mounting kit from Ronayers.com #K53021-094 for $110.84 it includes the tail light and helmet lock relocation bracket. The brackets keep the bags off the shock and was fairly easy to install.
Glenn Douglas
Londonderry, NH
GDouglas is offline
post #5 of 12 (permalink) Old 07-28-2009, 01:45 PM
fergy's Avatar
I broke the screw head off the right one and had to drill it out and use a similar screw and lock nut... Might be stuck!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 12 (permalink) Old 07-30-2009, 09:33 PM Thread Starter
CLARK47's Avatar
Thanks for the warning. Didnt think there would be that much to it. Unfortunately i dont have the money to purches the mounting kit. And i have never used the locks so ill give taking them off a try and hopfully they wont need to be drilled, (dont have a driil)
CLARK47 is offline
post #7 of 12 (permalink) Old 07-31-2009, 12:30 AM
IMBoring25's Avatar
It took extractors to get mine out. The Kawasaki kit includes new screws, so Kawasaki may have known that was going to happen.
On a newer bike, they might not be as stuck. Good luck.
IMBoring25 is offline
post #8 of 12 (permalink) Old 08-04-2009, 03:58 PM Thread Starter
CLARK47's Avatar
Ok, so the good old screw driver in vice grips didnt work,.... Any one in norfolk, va. With a impact driver??? Or whould it be out of the ordinary to go to my local bike shop for somthing that small?
CLARK47 is offline
post #9 of 12 (permalink) Old 08-04-2009, 04:16 PM Thread Starter
CLARK47's Avatar
And while im thinking of it, and before it comes up later, what do i do with my tail lights??? Can medium bags be mounted as to not obstruct the pasinger and to avoid the tail lights being in the way of opening them?? Do i need to git aftermarket ones?
CLARK47 is offline
post #10 of 12 (permalink) Old 08-04-2009, 04:51 PM
Newb with a Bullet!
krebsne's Avatar
I had the same problem with my sidecovers. The Harbor Freight impact screwdriver did the trick for cheap. Do you have one near you?
http://www.harborfreight.com/cpi/cta...emnumber=37530
Current VN: 03 VN1600A
Past VNs: 92 VN750A, 98 VN1500A
Future VN: 94/97 VN1500A basketcase/bobber
krebsne is offline
