Gas tank. Steel or Aluminum? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-28-2009, 08:36 AM Thread Starter
I want to get a magnetic tank map holder for my bike.I am out of town and can't check to see if the tank is steel or aluminum. Please advise.
Donna
'06 750 Vulcan
adelaidedarling is offline
post #2 of 7 (permalink) Old 05-28-2009, 08:49 AM
dirtrack650's Avatar
I uSed mag badgeS thiS paSt weekend on a memorial run. They didn't Stick very well So my gueSS iS it'S cheap Soft Steel. I checked the badgeS on my tool box and they Stuck tight.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 7 (permalink) Old 05-28-2009, 08:58 AM
Love My Baby
rubyrick's Avatar
Magnetic tank bags stick quite well on my 750. It's possible that dirtrack found the magnetic pull was stronger elsewhere on his bike when weak magnets are applied, but the strong magnets used on tank bags should pose no problem. That is unless you've repainted you tank with a thick coat of something that might interfere with the magnetic attraction, if there is such a thing.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 7 (permalink) Old 05-28-2009, 09:00 AM
carbon steel
dutter is offline
post #5 of 7 (permalink) Old 05-28-2009, 09:48 AM
phurp's Avatar
I have used my Cargo tank bag on a couple long trips. the magnets stick great. I used a shammy cloth under the bag to prevent any vibration wear damage.
1990 vn-750
metzler 880's
r/r relocated
iridium plugs
ngk plug caps
mf agm battery
ballancer and stator replaced. (Lance328)
Pro Tac Backrest
progressive fork springs
fork seals replaced
2003 kdx 220
frp chain gude
frp skid plate
acerbix hand guards
uni filter
phurp is offline
post #6 of 7 (permalink) Old 05-28-2009, 10:13 AM
I've used a Givi magnetic tank bag and had no problems with it holding, even at speeds around 75mph.
You can kinda see it in my sig pic, but here's the full size version...
Here I was using the shield, but it has held just as well with out it.
post #7 of 7 (permalink) Old 05-28-2009, 11:45 AM Thread Starter
Thanks to everyone for their prompt and helpful feedback.
This is a great site.
