Hard Luggage - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-19-2009, 08:04 PM Thread Starter
ctoons's Avatar
Hard Luggage
I want to make my Vulcan a better touring ride. I'm thinking hard luggage, but haven't had much luck finding anything that'll fit. I need some kind of rear luggage rack that will hold a 40L topcase, not the wimpy 5lb rack that seems to be the only thing I can find. No luck finding luggage racks to support detachable hard bags either. Does anyone know of anything that'll work. Someone who has made some custom pieces maybe?
It'd be nice to have a bigger gas tank too; any simple options there?
[FONT="Arial Black"]Ceci
Cleveland, TX
'06 HD XL1200L
'01 VN750 (Sidelined AGAIN for now)
'02 V-Star 650 Sold!
There and Almost Back Again- A Motorcyclist TaleFinally DONE!!!
ctoons is offline
post #2 of 9 (permalink) Old 05-19-2009, 09:50 PM
The 5lb rating on the stock rack (which is one of the better ones to choose) is just to remove chances of lawsuits against Kawasaki. It's been known to hold easily over 100lbs when used as a ladder of sorts (I believe it was Knifemaker who used it to stand on to change a lightbulb)
I've had well over 5lbs on mine many times with no problems.
As for hardbags, there's several here who've gone that route and should post soon.
A search of the forum should offer some insight also.
post #3 of 9 (permalink) Old 05-19-2009, 10:35 PM
The Professor
lance328's Avatar
The factory rack will support alot of weight, Kawasaki limited it to 5 lbs. so the bike would not go over the GVWR (gross vehicle weight rating)
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 9 (permalink) Old 05-20-2009, 05:50 AM
750Doug's Avatar
Somebody here recently installed some Givi hard bags that are quick detach. Try a search for Givi or hard bags. (I don't remember his screen name)
750Doug is offline
post #5 of 9 (permalink) Old 05-20-2009, 08:13 AM
Rider on the Storm
EasyRector's Avatar
I've carried a lot of gear on the stock Kaw rack with no problems.
Recently I added a relatively cheap but good-looking detachable/lockable tail case ~ an Emgo Portable Travel Trunk. It is VERY useful for carrying things while commuting.
A note of caution: loading up the tail rack DOES change the balance of the bike. This is most obvious to me when I mount a loaded bike while it is still on the center stand ~ it begins to tip backwards!
EZC
EasyRector is offline
post #6 of 9 (permalink) Old 05-20-2009, 08:46 AM
The Professor
lance328's Avatar
I think this is what you are refering to.
http://www.flickr.com/photos/jimfost...7600755200783/
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 9 (permalink) Old 05-20-2009, 08:54 AM
skalding's Avatar
I mounted some old samsonite small suitcases (metal and plastic). I ran longer bolts through the grab rails. To those bolts (using spacers to hold it away from the grab rails) I attached some lengths of bar stock to make a small brace. I bolted the suitcases to the brace. They're removeable (4 bolts) but not quick-detachable. They hold a ton and the weight sits low on the bike.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #8 of 9 (permalink) Old 05-20-2009, 02:31 PM
Senior Lurker
Sloppyburpfest's Avatar
Have a read through this thread https://www.vn750.com/forum/showthread.php?t=9851
The Givi bag thread was https://www.vn750.com/forum/showthread.php?t=988
But if money is no object for you and you really want easily detachable hard bags that were built for your bike, go to LeatherLyke. They have hard lockable saddlebags and tourpacks that look like they are made out of leather... http://www.leatherlyke.com/srchbike...._(Vulcan%20750)
My Flickr Gallery < Link >
Küryakyn LED battery monitor
R.I.P. Lance328
Sloppyburpfest is offline
post #9 of 9 (permalink) Old 05-20-2009, 10:51 PM
Love My Baby
rubyrick's Avatar
I've got a stock Kawi rear rack and it holds plenty. Recently road my baby to Key West with the wife and we used a Tourmaster Cruiser II luggage set with an attached barrel bag on top. The luggage attaches to the back of the seat and rests on the rear rack (the extended backrest would make it fit even better). Packed enough for a 3-day trip for the two of us, and it looked like it was made for the bike.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
