Mustang seat mounting issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 05-15-2009, 07:15 PM Thread Starter
Jace Bror's Avatar
So I got my 'new' mustang seat yesterday. I am having a problem with mounting it. Instead of like the stock seat which has built in nuts, it has thread bolts sticking out the back. And they are sooo long that the only way I could get it on was to remove the backrest and put it together. And now they are so long in fact that they almost hit the door of the rear 'glove' box.
Now is this normal? Cuz I can turn the threaded rods a little by hand, but the brass insert that they go into turns too and I don't want to break anything. I know I can cut the bolts shorter of course, but I just want to know if this is normal.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #2 of 3 (permalink) Old 05-15-2009, 07:36 PM
VulcanCruizer's Avatar
It sounds almost like my seat. Honestly I don't like the way my seat inserts are so I'm going to drill them out and get 1/8" x 2" x 6" (I think) and drill 4 holes in each corner and rivit it to the fiberglass on the seat then line up the mount holes and tap them. The ones I have now are like the things you get when you put a mount into sheetrock and tighten the screw and it pulls the "nut" tight. I hate those things... Anyway, it's just a thought.
1989 VN750
Purchased 4/26/2008 @ 27,320 Mi
Upgrades:
Travelcade Mustang Seat
SpitFire Tinted Quick Release Windshield
Degoat, Drilled & Jetted
Leather Saddle Bags
Johar Signature Grips
Deka ETX15L Powersports AGM Battery
NGK DPR7EIX-9
Upcoming:
1991 VN750 Project Bike
Purchased 4/30/2011 @ 31,970 Mi
VulcanCruizer is offline
post #3 of 3 (permalink) Old 05-16-2009, 10:25 AM Thread Starter
Jace Bror's Avatar
that would work. but i'm curious to know how the factory system from mustang was supposed to work.
