Pro-Tac or Saddlebags - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 05-12-2009, 11:06 AM Thread Starter
At Least I Can Spell!
msh1156's Avatar
Well I took delivery of my Pro-tac backrest last night after work. I assembled it easily as expected and find it feels and looks good. I look forward to using it instead of that damn cooler. (not too comfy)
BUT... the yoke on the saddlebags I have is wide where it zips on the bags, covering the flange for the Pro-Tac, making the bags useless with the Pro-Tac in place. No - a hole can't be cut in the yoke, can't be moved back.
(dammit)
So I have to decide - keep the bags and give up the support, or keep the support and then have to spend MORE MONEY on new bags. Look - I know this isn't a catastrophe but cripes... I don't have a money tree in my yard!!
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #2 of 15 (permalink) Old 05-12-2009, 11:24 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
Like my momma used to say, measure twice and buy saddlebags once.
Can you lower the bags to get around the backrest bracket? I have the pro-tac on mine and have my large bags on it as well, no cutting, just lowered them a 1/2 or so and they fit fine.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #3 of 15 (permalink) Old 05-12-2009, 11:29 AM Thread Starter
msh1156's Avatar
Not my mom... she says stuff like "Who are you? What are you doing in here? NURSE!!!"
Who knew you had to measure???
First bike... first bags...
I could re-tie the yoke and lower them but I think they'd sit too low against the support brackets. I'll try that though.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #4 of 15 (permalink) Old 05-12-2009, 11:50 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
Mine fit nicely by lowering the. But if that didn't work and I had to make a choice, hands down it would be keep the back rest, it has saved my back and let's me ride longer! Might have to relocate the turn signals and move them back a little. I'm looking for a relocation kit so I can do mine, they are hard to find.
post #5 of 15 (permalink) Old 05-12-2009, 01:41 PM
fergy's Avatar
Just don't let em sit on the pipes! I had to grind down my saddlebag support front mounts so the protac mount would sit back and rest on the side rail. Otherwise I was forced to lean forward which lasted one ride. It might take some riggin but hopefully you'll find the right combo! Maybe take some photos and post em for more off the wall ideas from the group...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 15 (permalink) Old 05-12-2009, 01:47 PM
Jace Bror's Avatar
Holy crap, good thing I wasn't drinkin milk when I read that.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #7 of 15 (permalink) Old 05-12-2009, 03:32 PM
The Professor
lance328's Avatar
You can cut a hole in the yoke and then install the backrest.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 15 (permalink) Old 05-12-2009, 03:44 PM Thread Starter
msh1156's Avatar
Thought of that... it's a pretty thick zipper that at the moment rests right on the pro-tac bracket. I'm going to attempt to lower it some by re-tyeing the yoke, moving the zipper past that point and maybe clearing a spot for that hole, but there's not a lot of room before they get too close to the mufflers.
I really want saddlebags, but I want riding comfort more. I may just have to save up for a different set of bags if this won't work.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #9 of 15 (permalink) Old 05-12-2009, 04:34 PM
Have you considered going yokeless?
Many have. With many different types of bags.
Depending on the bag, there are seveal ways to do this. Most folks make their own supports, but I think there are a few on the market, like this one:
http://www.chromeworld.com/index.cfm...categoryID=843
(sorry tinyurl ain't working)
You will have to alter the bag in some way. Usualy means punching some holes in it's back.
Am sure someone that has done this can give you more information.
post #10 of 15 (permalink) Old 05-12-2009, 04:49 PM
cm4cm5's Avatar
thats what i did with my saddlemen bags. i bought them yokeless. i used the bolts that the supports mounted with. went through the back of the bags, through the support, into the nut. there is a strap on the bottom of the bags that went around the support to secure the bottom of the bags.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
