Plexistar 2 Mounting Pics - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-09-2009, 04:01 PM Thread Starter
flitecontrol's Avatar
I've looked here and can't find the detailed pictures I need to get this %#@*& windshield mounted where the hand extensions cover the grips AND it doesn't rub something! Anyone know where good, detailed pics are?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #2 of 7 (permalink) Old 05-09-2009, 04:08 PM
The Professor
lance328's Avatar
I have some pics of mine that may help, keep the angle of the shield the same as the forks.
https://www.vn750.com/photopost/showg...00&ppuser=4152
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 7 (permalink) Old 05-09-2009, 04:50 PM Thread Starter
Thanks, lance. Like the others I've found here there just isn't enough detail. What I need are closeups of the brackets. Where and how they're mounted, length of adjustment, etc.
"Black Beauty"
Old Blue
post #4 of 7 (permalink) Old 05-09-2009, 05:58 PM Thread Starter
Ignore. Sawed off the offending parts!
"Black Beauty"
Old Blue
post #5 of 7 (permalink) Old 05-09-2009, 07:25 PM
At Least I Can Spell!
msh1156's Avatar
I have the same shield... again. That meaning I had swapped it out for the Street Shield EX before riding into the ditch - which killed the EX. (insert group sigh here) Now I'll be using the Plexi 2 for the road trips. Nice thing about it - once the hardware is set on the forks and handlebars it goes on and comes off in about 30 seconds.
It took some patience and little tweaks here and there to get that thing to:
  1. Sit just a hair over the headlight
  2. sit behind the directionals without hitting them
  3. get the angle set in line with the forks
I can tell you this... it won't cover up the grips like you see in other pictures. I learned this shortly after lining everything up. Our handlebars sit higher, so it will be less directly in front than just a bit below. But it's enough to deflect I assure you.
I don't have the screen on the bike now, but here are some pics of the hardware as it is installed - ready for a quick mount. (in two parts) Hope this helps.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #6 of 7 (permalink) Old 05-09-2009, 07:26 PM
msh1156's Avatar
Part two
The Album in my profile shows the whole thing mounted (under modifications)
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #7 of 7 (permalink) Old 05-09-2009, 08:04 PM Thread Starter
Thanks! Wish I'd had those when I started this frustrating process! Need to post these somewhere so others can at least start out with the brackets in the right position! Phots are extremely helpful!
"Black Beauty"
Old Blue
