Silicone on Chrome Swing Arm Caps? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-09-2009, 11:39 AM Thread Starter
Question Silicone on Chrome Swing Arm Caps?
Hey Folks --
How do you put the silicone adhesive on the chrome caps that cover the swing arm connection to prevent them from falling off?
Do I remove them first and put the silicone underneath? If so, how do the caps come off. My bike is a '94 and the caps are on VERY tight. The left one appears to be rusted on.
Can I just pust a thin bead of silicone where the cap meets the metal?
What are your thoughts?
FlaRider is offline
post #2 of 17 (permalink) Old 05-09-2009, 12:33 PM
They pry off. My caps on my '93 have a small notch on the edge you can use a screw driver to pop them off. I used a little silicone around the inside and snapped it back on.
Glenn Douglas
Londonderry, NH
GDouglas is offline
post #3 of 17 (permalink) Old 05-09-2009, 04:10 PM
X2 to above^^^^^^.
Also make sure to position the little notch so that you can get a screwdriver blade into it when you need to take it off.
post #4 of 17 (permalink) Old 05-09-2009, 05:11 PM Thread Starter
Originally Posted by OlHossCanada View Post
X2 to above^^^^^^.
Glenn, OlHoss --
I'll look for the little notch. Many Thanx for your responses!
FlaRider is offline
post #5 of 17 (permalink) Old 05-09-2009, 11:15 PM
Also, some have mentioned having trouble keeping the caps on while the silicone is drying.
Just use some tape to hold them on until dried and everything should be good to go!
post #6 of 17 (permalink) Old 05-10-2009, 08:21 AM
At Least I Can Spell!
msh1156's Avatar
so what would happen if you ride around missing a cap - or both??
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #7 of 17 (permalink) Old 05-10-2009, 08:35 AM
skalding's Avatar
I think the bike will explode. But I've been known to be wrong on this stuff.
Seriously - I lost a cap awhile ago, so I just "waterproofed" the swing arm with a bunch of grease then wiped it down. It's fine so far. I thought about making a cap instead of buying one. I was considering using tin snips to cut out the bottom of a soda can, then using silicone to put it on. Never got around to it though.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #8 of 17 (permalink) Old 05-10-2009, 10:56 PM
electrum's Avatar
both caps were missing when i got my bike. i bought new ones from the dealer, $10 a piece.
they are plastic however, not metal.. so i don't know what the rust would be from, unless they also made tin ones.
mine were very hard to get on straight.. i had to smack them a lot with a hammer wrapped in shop towels until it was seated around the whole perimeter.
i'm thinking they won't just fall off, but i siliconed them before installing just to be safe.
96 Vulcan 750
electrum is offline
post #9 of 17 (permalink) Old 05-10-2009, 11:41 PM
I lost mine. I'll have to check e-bay and pay high shipping charge. But next time I will use the silicone to prevent this from happening again.
John Brisson is offline
post #10 of 17 (permalink) Old 05-11-2009, 08:35 AM
That's what most who have lost one or both thought too (myself included)
Good thing you did silicone them anyhow!!
