throttle tube (handle mount) broken :( - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 16 (permalink) Old 09-04-2019, 10:58 AM
Originally Posted by Dokuji View Post
I mean the spacing on the cable mounts themselves. lots of people said they needed shaving etc, or that the diameter of the tube itself was too loose on the bars. stuff like that I wanted to avoid.
If i ever break another one I'm going to upgrade to an aluminum one
Those must be some really old posts, I haven't seen that mentioned since I got here.
I can't rave enough about my ISO grips though, love'em. Going to put them on my ATVs!
post #12 of 16 (permalink) Old 09-04-2019, 11:58 AM
mmart's Avatar
Here’s the grips I bought, it stated “fits your vehicle”, but when I installed them I noticed that the cable slots were slightly different. More importantly with the switch housing reassembled it wouldn’t allow it to snap all the way back so that a big no no. The PO has changed the grips and you can tell they reused the tube so I followed suit. Classic case of 10 min job taking an hour. For the left side I had to wrap the bar with tape first to get it snug and then glued the grip to the tape.
mmart is online now
post #13 of 16 (permalink) Old 09-04-2019, 12:18 PM
Sounds like maybe they are 1" grips. I had a set but didn't put them on. That tape wrap is sketchy, I've had a left grip slide off while moving, on an atv luckily.
I wasn't aware of the cable issue, have seen posts about the gap between the switches and throttle, I think maybe on the Goldwing ISOs, which are longer than most.
post #14 of 16 (permalink) Old 09-04-2019, 01:24 PM
mmart's Avatar
They were labeled as 7/8’s grips, a buddy an I performed some rigorous QA testing to make sure that puppy was secured lol, I’ll mostly likely have to cut it off if I ever replace them lol.
mmart is online now
post #15 of 16 (permalink) Old 09-04-2019, 01:43 PM Thread Starter
Dokuji's Avatar
yeah, this is why i went OEM :P
Dokuji is offline
post #16 of 16 (permalink) Old 09-04-2019, 02:20 PM
mmart's Avatar
At the end of the day the bottom line is no matter how awesome the 750 is, it’s an oddball bike. Nothing is as easy as it should be
mmart is online now
