eBay digital speedometer question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-28-2018, 01:48 AM Thread Starter
PlanetVulcan510's Avatar
Has anyone bought one and installed it? I just recently got one and having trouble wiring it up.
PlanetVulcan510 is offline
post #2 of 10 (permalink) Old 03-28-2018, 11:46 AM
I'm a rider
One1's Avatar
Be more specific about having trouble wiring it up.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #3 of 10 (permalink) Old 03-28-2018, 03:30 PM
Aye. What wires does it have, and which of those wires have you tried to attach where?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 10 (permalink) Old 03-28-2018, 08:03 PM Thread Starter
It has a ground wire – no problem there
It has any power wire – hooks up to the ignition switch, no problem there
Got a memory/power wire – hooks up directly to the battery, no problem there
Turn signals work with no problem as well as the neutral indicator light
Where I’m having a problem is with the tach. It is very slow to respond and sticks.
Fuel gauge is working, but I do not think it’s accurate.
And my highbeam indicator light is constantly on.
post #5 of 10 (permalink) Old 03-28-2018, 08:05 PM Thread Starter
This is the speedo/tach I bought on eBay
post #6 of 10 (permalink) Old 03-28-2018, 09:41 PM
Well, it sounds like you have it wired up correctly, if you're getting any response from it at all.
For the fuel gauge, the fuel level sensor wire is the white one.
For the tach, the black wire is the signal wire and is shorted to ground every time one (can't remember if it's the front or the rear) coil fires.
I'm just spitballing, and maybe someone else has a better idea, that maybe the IC box that controls the spark timing doesn't provide a clean square wave signal on the black wire, which may be causing problems for the digital tachometer? You might be able to find some sort of filter that would clean up the signal a bit before it hits the tach. Maybe just cleaning up the connectors at the IC box and ground would give you a more decisive path to ground more stable signal.
Thorn is offline
post #7 of 10 (permalink) Old 03-28-2018, 10:15 PM Thread Starter
Thanks for the help!
Question though, I noticed on the wiring diagram that there are three wires on the tach and three wires on the fuel gauge. One is for the sensor, one is for ground, and one is brown that leads to the junction box/ignition switch. I do not have a spot to put that wire on my new Speedometer. Question is, is that needed for the fuel gauge and the tach or should I Cap it?
post #8 of 10 (permalink) Old 03-28-2018, 11:10 PM
Those brown wires are the +12v lines when the ignition switch is "on". You said you were already pulling power from the ignition switch to the new module, so those leads are just extraneous now. Cap 'em.
Thorn is offline
post #9 of 10 (permalink) Old 03-29-2018, 12:53 AM
I'm a rider
One1's Avatar
Only caveot to lack of power wires is if you're on an underpowered line. You may not be on a line supplying proper amperage or voltage into the cluster. Check and verify voltage with everything on and running. If you have a voltage drop at the unit with it on, but proper voltage coming in with it off, your supply in line isn't keeping up with demand. A weak ground can simulate this effect.
1981 KZ750
One1 is offline
post #10 of 10 (permalink) Old 03-29-2018, 11:47 AM Thread Starter
Thanks guys. A lot of great help. Hopefully I can figure out the issue this weekend because it’ll be nice to ride here in the SF Bay Area
