Fork fluid - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-07-2017, 04:14 PM Thread Starter
Connor Lynden's Avatar
Fork fluid
So I resently had about half of the fork oil leak out from the left side fork so needless to say I need to fix that, I cleaned the seals and they seem to be working fine now, haven't had any more oil leak out. But anyways I want to rebuild them with progressive springs. So two questions, has anyone tryed the progressive springs and if so what is your opinion on them vs stock? Also what fork oil should I put in them after rebuild?
Connor Lynden is offline
post #2 of 5 (permalink) Old 11-07-2017, 04:33 PM
I used atf in mine.
Loosen the allen-head bolt that goes up through the bottom of the fork before removing the front wheel. This bolt has Loctite on it, so some heat might keep you from stripping out the head.
post #3 of 5 (permalink) Old 11-07-2017, 06:33 PM
I highly recommend the Progressive fork springs. See the write ups in the Verses. I used 15w Bel-Ray, but I had a large windscreen. 10w works fine. Yes, you can use ATF fluid, but there is no info on viscosity.
post #4 of 5 (permalink) Old 11-07-2017, 06:51 PM
I had the info on atf viscosity, but don't have it now. Was close to the factory fork oil, 10w or 20w, I forget. Internet shows 10 to 20w.
I used the correct amount, but the forks ended up being a bit stiffer than I'd like, they were a bit springy before, so it was an improvement. I'm pretty sure the oil was low before the rebuild, and they had water/moisture buildup. For the stiffness I thought I might use less atf or get 10w fork oil. They absorb bumps more like a dirt bike fork than a street bike right now, but they do handle nice.
The original oil is most likely gonna be milky and stinking like a dead whale. yuck!
post #5 of 5 (permalink) Old 11-08-2017, 11:52 AM
cglennon's Avatar
cglennon is offline
