Rear Brakes siezed after wintering the bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 01-03-2009, 11:31 AM Thread Starter
I have been leaving the bike outside during the bad weather, under canvas and starting it up every couple of weeks
Came to the bike today to discover the rear brakes seized on. After pressing the rear pedal i found the brakes well and truly seized on. The only way to release it is to undo the adjusting nut on the end of the rod and disconnecting the rod.
Then with the aid of brute force i can operate the lever on the drum manually back and forth but with difficulty
So it looks like a stripdown as i have sprayed all the external moving parts with WD40 with no luck, Now heres the problem, i am not good on the spanners but willing to have a go as i have already had an expensive christmas.
I have read the Haynes manual over and over and have come up with the following questions
A) Do i rearly need a torque wrench
b)The book says to raise the FRONT wheel off the ground, by use of a jack, wont that make thing awkward when the rear wheel is removed, Where is it best to position the jack
C)Which part is likely to be seized up inside the drum
D)Do i need to remove the right hand exhaust completely as it mentions the Muffler but i dont know what that is
E)Do i need any gaskets, etc
F) is it best to renew the shoes on replacement and are there any pitfalls which the manual does not mention
Hope you can offer some advise as this remains rather daunting to perform
pgchimp is offline
post #2 of 20 (permalink) Old 01-03-2009, 11:41 AM
Vintage bike addict
antiq's Avatar
If there were no issues with the brakes before storage. I'd get a GOOD penetrating oil like PB Blaster and spray the shaft going into the hub and manualy work the lever until it moves freely again.
Eleanor Roosevelt.
antiq is offline
post #3 of 20 (permalink) Old 01-03-2009, 12:07 PM Thread Starter
Hi Antig
There were no issues before storage regarding the brakes sticking on, however since i have owned the bike (6 months now) the brake pedal has never been up to much.
The wear indicator is mid range but i rearly had to tread on the pedal before i even started to slow down and due to this only ever used the front brake to stop.
I could virtually stand on the brake pedal and still not stop
I have sprayed and sprayed a release agent on the shaft trying to work the lever by hand but it sure aint giving so it looks like a stripdown
pgchimp is offline
post #4 of 20 (permalink) Old 01-03-2009, 02:17 PM
Calif Rider
weh44att's Avatar
Pgchimp this is furgy's write up of how to remove rear wheel. This should answer about any question you may have about how to do it. There are pictures and all the info you need to check your brake, as for what is wrong you will have to pull the wheel and do a good inspection of the the brakes. http://pages.tstar.net/~fergy/writeups/final_drive.html
. If this does not work try typing in Furgy's spline lub.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 20 (permalink) Old 01-03-2009, 03:35 PM
Vintage bike addict
antiq's Avatar
If the brake was useless before than I wholeheartedly agree a teardown is in order. Here's hoping a little cleaning and adjustment will put you right.
Eleanor Roosevelt.
antiq is offline
post #6 of 20 (permalink) Old 01-03-2009, 05:56 PM
With time on my hands, I`ve done a little research pgchimp. Weh44`s link to fergy`s link is a good one. It shows how to remove the rear wheel and check and grease the driveshaft and final drive, and put it all back together. I couldn`t easily find a link to the rest of his website, so I searched "rear+brake+replacement" and found 750 Doug`s thread from about 6 months ago. He has some good pics of the brake drum and brake shoe plate assembly and explaination of what was done. I bumped it up, so if you go to the top of this page and click on Quick Links, then on Todays Posts, you will find 750Dougs post with pics, at or near the top of the listings.
Now in answer to your questions, you definately need to pull the rear wheel and find and remedy that brake problem.
Q1. Yes you need a torque wrench. It does not have to be expensive,(I picked up one a few years ago at a discount place for about $20, IIRC). You do want to get a 1/2" drive, micrometer style adjustment, with an audible click, torque reached indicator. The beam type with a scale and a pointer are cheaper to buy, but very awkward to use. Stay away from them. If your sockets are 3/8" drive make sure you have a 3/8" to 1/2" adapter for the torque wrench.
Q2. Don`t lift front wheel. Park with center stand sitting on a piece of 2" lumber, as shown by fergy and 750Doug. This will lift your rear tire high enough to get the rear tire and wheel out without deflating it. Remember to tie the center stand to the front wheel so you don`t roll the bike ahead and off the stand, (also as per fergy`s directions).
Q3. I am guessing, based on your description, that the shoes are probably stuck to the drum. Make sure that you check, clean, adjust and lube all pivot points in the linkage and cable from the pedal all the way back to and including the rear brake camshaft. Ensure that you don`t get any grease on the shoes or internal drum surface.
EDIT.- After re-reading your 1st post a few times, I conclude that antiq rightly identified the problem in the next post as the camshaft, not the brake shoes sticking to the drum per se. The camshaft lever is not releasing and turning back to its "at rest" position. Therefore the camshaft remains in the "brakes applied position." It could be that the shoes are in good condition and all that is needed is a good cleaning and relubrication of the camshaft and brake assembly plate
Q4. You should only need to remove the right muffler and cover which is the rearmost piece on the exhaust pipe. It is about a foot and a half long. Directions and pics are in the Clymer manual. Look at the pipe directly below the right rear passenger footpeg and you will see the connection point. There are 2 bolts below to remove to get the cover off. One more on the clamp holding the muffler to the exhaust pipe , and another just under the footpeg which supports the muffler. That`s it.
Q5. As long as you have the back end this far apart you should check and clean the rear splines and final drive. There are not many gaskets on this bike but there are some O-rings in there that probably should be replaced. You will have to check the pdf file available here or the diagrams and parts list on ronayers.com for part numbers. Seeing that it is a few months before you will be riding, you may want to pull it apart to determine exactly what you need so you can get everthing in one order. Anyone else out there have any advice on this?
Q6. You probably will need new brake shoes, but if you have a space to work in where you can leave the bike partially dismantled, with the parts laid out in order ,and no one will disturb them, see the second to last sentence in the paragraph above.^^^
I hope this helps pgchimp. I`m sure others can fill in anything I have missed or forgotten. I see you have the Haynes manual, not the Clymer that I use, so there are bound to be differences in pics and approach etc. In any event, take the manual, read and mark relevant sections and get a notebook to write notes, question, diagrams, etc. Then take it out to your workspace and review what you need to do while looking at the corresponding area of the bike. Make sure you have all the tools you will need. Have on old towel or blanket laid out on a bench or shelf where you can keep everything in the order it came off, to simplify reassembly later. If you have a Polaroid or a digital camera, take some pics before you start and as you progress to aid in assembly also.
Now is also a good time to check several other things while the rear wheel is already off, such as;
The wiring that runs along a channel in the underside of the rear fender to the rear lights.
The condition, lubrication and adjustment of the pivot bearing for the swingarm, driveshaft assembly.
Condition of the battery and battery box, (need cleaning and/or paint?), all electrical connections under the seat are clean, free of corrosion and sealed with dielectric grease.
Look for any cracks or scratches in the frame that need to be repaired or painted.
Good time to relocate regulator/rectifier if so desired.
Anything else you can think of, or find in the manual, that is easier to get at now, than it will be later when you would rather be riding.
Don`t get overwhelmed or discouraged by this list. Take it one step at a time, at your own pace, and set your own priorities about what needs to be done first. This is just my list of some things I need to check on my scoot. Make your own list and when you get tired or frustrated with the project, stop and take a break. Take it slow and be sure it`s right, rather than rush and have to pull it apart again. Don`t ask how I know this!! Good luck.
post #7 of 20 (permalink) Old 01-04-2009, 07:25 AM Thread Starter
Many thanks for all your comprehensive replys, you have inspired me with confidence to perform both tasks............ Rear shoes and spline lube
However i have downloaded FERGYS 21 pages for reference and just have a couple more points i would like clearing up before i start
A)The Haynes manual says to remove the right muffler and not bother removing the lower shock mounts. Fergy suggests removing both lower shock mounts and no mention of muffler removal.
Is Fergys way better as the connection at the muffler is seized solid and possibly will not seperate from the exhaust. I note that in all of Fergys pics both mufflers remain inplace
B)Fergy says to remove the 4 bolts for the right passenger foot mount to give wiggle room for the right exhaust pipe so you can remove the lower right shock nut I dont understand this sentence????????????????/
C) Finally the manual says QUOTE................................
1)>>>>>>>>>>>>>>>>>>>
2)>>>>>>>>>>>>>>>
3)Remove the rear wheel
4)Remove the Four differential mounting nuts and take the differential off the driveshaft housing (SEE ILLUSTRATION) THe Spring thats installed on the rear end of the driveshaft will come off with the differential
There is no mention of a spring in Fergys breakdown of this split, has he missed it out as i dont need any nasty suprises with a spring flying out never to be seen again
Hope you can clear up these few points
regards
pgchimp is offline
post #8 of 20 (permalink) Old 01-04-2009, 08:07 AM
I did not remove the muffler, as removing the shocks seemed easier. While I had the shocks off, I changed the shock oils, which was a lot harder job.
Me neither. I had no trouble with the shock nuts. If you don't remove the shocks completely, just loosen the upper nuts and the lower ends should come off easily.
There is no mention of a spring in Fergys breakdown of this split, has he missed it out as i dont need any nasty suprises with a spring flying out never to be seen again.
Yes, there is an important spring, but it won't fly out. Worst case drop on the floor and roll out of sight never to be seen again.
pappa is offline
post #9 of 20 (permalink) Old 01-04-2009, 09:04 AM
I did not remove mufflers either. I removed the lower end of shocks only. I lowered the wheel enough to clear the muffler to remove the axle.
The spring will not fly out. Just note in what order it comes out.
Probably your prob is at the shaft that goes into the brake housing. The one on the right side. You may want to oil the brake peddle pivot also.
post #10 of 20 (permalink) Old 01-04-2009, 09:13 AM
750Doug's Avatar
Here's some reason's why the steps/techniques vary-
The rear wheel needs to hang low to be removed from under the fender. One way to do this is pull both shock so the swing arm hangs free. I did mine by putting the bikes center stand onto a 3/4" piece of plywood which raises the back end off the ground 1-2 inches, leaving more than enough room for wheel removal. Done this way, only the left shock needs removed as it connects directly to the drive unit. If you're not removing the drive unit, the left shock can stay. Removing the left shock helps make a little more room to install the drive unit if you need to twist it side to side to install, or just remove the lower mount nuts.
The spring inside the drive unit will not "spring out" but as mentioned might fall out and roll away. Spread out a towel under the drive unit and if the spring falls, the towel will keep it from rolling.
The reason for pulling the right hand muffler is the axle bolt. They (usually) go in from right to left, so after you take the nut off, this very long bolt needs to slide out to the right and it needs room to do so; also, can you get tools onto the nut and bolt head with the current exhaust in place? If not, they need removed. I had Jardine pipes on my bike for a while and didn't have to touch the exhaust to pull the rear wheel, so this depends on your setup.
This is why there is differences in the book, and Fergy's write up....
The wheel needs to be high off the ground for removal, downward and out. (high means an inch or two of clearance)
The exhaust gets removed, if needed to access the hardware, and to allow the axle bolt enough room to the right to slide straight out.
Clear as mud?
The first time everybody is about to do this job, they are way more apprehensive than they need to be. It's very easy, and fairly quick, and once you dive in, you'll understand why the written stuff is written like it is.
750Doug is offline
