moving rear shock - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-10-2017, 06:48 AM Thread Starter
Rebar1968's Avatar
Talking moving rear shock
hello just wondering I have been doing some reading , I see you can make a kit to lower the rear or swap out the shocks, has any one just moved the top mounting hole ?? I was looking at maybe just using the first or second back rest hole as I will no longer be using the back rest
Rebar1968 is offline
post #2 of 6 (permalink) Old 03-10-2017, 08:53 AM
Tinkerer
Gaz73's Avatar
Personally, without strengthening the frame I wouldn't recommend using the back rest holes. Plus moving the top mount backwards will totally alter the the rear end set-up, again something personally I wouldn't do. Buying shorter shocks is the easiest option or making the lowering brackets like you've already mentioned.
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #3 of 6 (permalink) Old 03-10-2017, 09:11 AM
Suzuki savage or s40 boulevard shocks lower it about 3" and bolt on.I move the forks up in the trees to bring the rake back and had to relocate the rectifier as the swing arm was hitting it after lowering
post #4 of 6 (permalink) Old 03-10-2017, 11:48 AM
+1
Get shorter shocks or a real lowering kit (that moves the bottom of the shock back more)
post #5 of 6 (permalink) Old 03-10-2017, 01:37 PM
+1
no one makes a lowering kit for a vn750 that I know of. Slimvulcanrider made one for himself. I'll see if I can find pics
post #6 of 6 (permalink) Old 03-10-2017, 06:09 PM Thread Starter
Rebar1968's Avatar
ok thanks it was just a thought I had seeing how it will be wasted space after altering it for the 900 seat.. most likely so the s40 shocks thanks for all the info
