Front Brake Issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 12-04-2016, 05:45 AM Thread Starter
Front Brake Issue
Howdy everyone. I was hoping to get some help diagnosing my front brake issue. So basically what happens is when I go to pull the brake the first pull there is nothing, I almost have to pump the lever for it to work. I've bled the brakes and it's got new fluid. Any suggestions?
ninjafaces is offline
post #2 of 13 (permalink) Old 12-04-2016, 09:46 AM
probably still air in the system. these brakes are notoriously hard to bleed.
many have had luck with tying the brake lever back and letting it sit overnite. That is what I did with mine, and at least got some feel in the handle. then after a bit of time, its nice and solid
michiganteddybear is offline
post #3 of 13 (permalink) Old 12-04-2016, 01:28 PM
I took a piece of clear vinyl tubing that fit tight over the bleeder screw. Then I just sucked the air bubbles out by just cracking the bleeder screw one at a time till no more bubbles. Then I tied the handle overnight and no more problems.
post #4 of 13 (permalink) Old 12-04-2016, 02:19 PM Thread Starter
I'll pickup some tubing tonight, thanks for the recommendation.
post #5 of 13 (permalink) Old 12-05-2016, 10:15 AM Thread Starter
So picked up a bleeder from autozone, bled the brakes, solid fluid no bubbles. Issue still persists and it appears like a bit of fluid is pooling at the bottom of the brake lever. I'm thinking bad master.
post #6 of 13 (permalink) Old 12-05-2016, 01:41 PM
"it appears like a bit of fluid is pooling at the bottom of the brake level..."
If you're saying it's leaking fluid...yeah, that's not good. Make sure all your connecting banjos are tight.
Did you tie the lever back overnight?
post #7 of 13 (permalink) Old 12-05-2016, 03:34 PM
did you overflow the master at any point or spill any fluid?
post #8 of 13 (permalink) Old 12-05-2016, 07:45 PM Thread Starter
Yeah I checked the connections they're not leaking.
Spilled a bit of fluid filling it up a while back but I cleaned it up.
post #9 of 13 (permalink) Old 12-05-2016, 08:31 PM
is it leaking out the window?
post #10 of 13 (permalink) Old 12-06-2016, 05:39 PM Thread Starter
Nope, I'm not sure where it's leaking if at all. There is no noticeable drop in fluid levels.
